Discuss
Back Of Freezer Wall Frozen With Ice, Fridge Not Cold
 in
Refrigerator & Freezer Repair
Fridge all of a sudden would not get cold even with it set on coldest. Then the freezer was not
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Back Of Freezer Wall Frozen With Ice, Fridge Not Cold
  #1 (permalink)
Old 05-26-2009, 04:26 PM
Junior Member
AustinLaBudda is on a distinguished road
Exclamation Back Of Freezer Wall Frozen With Ice, Fridge Not Cold
Model Number: ESS2XGMD   Brand: GE   Age: 1 - 5 years
Fridge all of a sudden would not get cold even with it set on coldest. Then the freezer was not freezing and basically turned into the fridge. The ice that had been there started melting. Took off back of freezer wall and the entire thing was frozen solid with ice. I melted the ice with a blow dryer and magically the fridge was cold again and the freezer was freezing again. However this only lasted a few days and it started doing the same old stuff. I would greatly appreciate the help as I do not have the money right now to pay someone to fix it.
Related Models
Amana ESS306-2D RANGE- S/C S/I DDRAFT GAS
Amana ESS307 RANGE- S/C S/I DDRAFT ELE
Amana ESS307-OF RANGE- S/C S/I DDRAFT GAS
Amana ESS341 RANGE- S/C S/I DDRAFT ELE
Amana ESS341-OF RANGE- S/C S/I DDRAFT GAS
Amana ESS342-OF RANGE- S/C S/I DDRAFT GAS
Amana ESS343 RANGE- S/C S/I DDRAFT ELE
Amana ESS343-OF RANGE- S/C S/I DDRAFT GAS
Amana ESS344-OF RANGE- S/C S/I DDRAFT GAS
Amana ESS345 RANGE- S/C S/I DDRAFT ELE
Amana ESS345-OF RANGE- S/C S/I DDRAFT GAS
Amana ESS347 RANGE- S/C S/I DDRAFT ELE
Amana ESS347-OF RANGE- S/C S/I DDRAFT GAS
Amana ESS349 RANGE- S/C S/I DDRAFT ELE
Amana ESS356 RANGE- S/C S/I DDRAFT ELE
Amana ESS356-OF RANGE- S/C S/I DDRAFT GAS
Amana ESS357 RANGE- S/C S/I DDRAFT ELE
Amana ESS357-OF RANGE- S/C S/I DDRAFT GAS
Amana ESS38 RANGE- S/C S/I DDRAFT GAS
Amana ESS380-OF RANGE- S/C S/I DDRAFT GAS
Amana ESS394 RANGE- S/C S/I DDRAFT ELE
Amana ESS397 RANGE- S/C S/I DDRAFT ELE
Amana EST307 RANGE- S/C S/I DDRAFT ELE
Amana EST308 RANGE- S/C S/I DDRAFT ELE
 EST3102K RANGE- S/C S/I ELE
 EST3102L RANGE- S/C S/I ELE
 EST3102W RANGE- S/C S/I ELE
 EST3102WW RANGE- S/C S/I ELE
Amana EST345 RANGE- S/C S/I DDRAFT ELE
Amana EST346 RANGE- S/C S/I DDRAFT ELE
Amana EST347 RANGE- S/C S/I DDRAFT ELE
Amana EST356 RANGE- S/C S/I DDRAFT ELE
Amana EST357 RANGE- S/C S/I DDRAFT ELE
Amana EST380 RANGE- S/C S/I DDRAFT ELE
Amana EST381 RANGE- S/C S/I DDRAFT ELE
Amana EST385 RANGE- S/C S/I DDRAFT ELE
Amana EST386 RANGE- S/C S/I DDRAFT ELE
Amana EST387 RANGE- S/C S/I DDRAFT ELE
Amana EST399 RANGE- S/C S/I DDRAFT ELE
Amana EST3992L RANGE- S/C S/I DDRAFT ELE
Amana EST3992W RANGE- S/C S/I DDRAFT ELE
Amana EST3A1 COMMERCIAL MICROWAVES
Amana ESU12HW FREEZER- VERTICAL
Amana ESU12JW FREEZER- VERTICAL
Amana ESU13 FREEZER- VERTICAL
Amana ESU13-A FREEZER- VERTICAL
Amana ESU13-AG FREEZER- VERTICAL
Amana ESU13-C FREEZER- VERTICAL
Amana ESU13-L FREEZER- VERTICAL
Amana ESU13B FREEZER- VERTICAL
Amana ESU13B-A FREEZER- VERTICAL
Amana ESU13B-C FREEZER- VERTICAL
Amana ESU13B-G FREEZER- VERTICAL
Amana ESU13B-L FREEZER- VERTICAL
Amana ESU13C FREEZER- VERTICAL
Amana ESU13C-A FREEZER- VERTICAL
Amana ESU13C-C FREEZER- VERTICAL
Amana ESU13C-G FREEZER- VERTICAL
Amana ESU13CL FREEZER- VERTICAL
Amana ESU13D FREEZER- VERTICAL
Amana ESU13DW FREEZER- VERTICAL
Amana ESU15 FREEZER- VERTICAL
Amana ESU15-A FREEZER- VERTICAL
Amana ESU15-AG FREEZER- VERTICAL
Amana ESU15-C FREEZER- VERTICAL
Amana ESU15-L FREEZER- VERTICAL
Amana ESU15B FREEZER- VERTICAL
Amana ESU15B-A FREEZER- VERTICAL
Amana ESU15B-C FREEZER- VERTICAL
Amana ESU15B-G FREEZER- VERTICAL
Amana ESU15B-L FREEZER- VERTICAL
Amana ESU15C FREEZER- VERTICAL
Amana ESU15C-A FREEZER- VERTICAL
Amana ESU15C-C FREEZER- VERTICAL
Amana ESU15C-G FREEZER- VERTICAL
Amana ESU15CL FREEZER- VERTICAL
Amana ESU15D FREEZER- VERTICAL
Amana ESU15DW FREEZER- VERTICAL
Amana ESU15HW FREEZER- VERTICAL
Amana ESU15JW FREEZER- VERTICAL
Amana ESU17 FREEZER- VERTICAL
Amana ESU17-A FREEZER- VERTICAL
Amana ESU17-AG FREEZER- VERTICAL
Amana ESU17-C FREEZER- VERTICAL
Amana ESU17-L FREEZER- VERTICAL
Amana ESU17B FREEZER- VERTICAL
Amana ESU17B-A FREEZER- VERTICAL
Amana ESU17B-C FREEZER- VERTICAL
Amana ESU17B-G FREEZER- VERTICAL
Amana ESU17B-L FREEZER- VERTICAL
Amana ESU17C FREEZER- VERTICAL
Amana ESU17C-A FREEZER- VERTICAL
Amana ESU17C-C FREEZER- VERTICAL
Amana ESU17C-G FREEZER- VERTICAL
Amana ESU17CL FREEZER- VERTICAL
Amana ESU17D FREEZER- VERTICAL
Amana ESU17DW FREEZER- VERTICAL
Amana ESU17HW FREEZER- VERTICAL
Amana ESU17JW FREEZER- VERTICAL
Amana ESU20HW FREEZER- VERTICAL
Amana ESU20JW FREEZER- VERTICAL
Amana ESU513 FREEZER- VERTICAL
  #2 (permalink)
Old 05-26-2009, 04:45 PM
Hardcore DIY'er
APP Volunteer
woodchuckie is on a distinguished road
Default
check defrost timer, defrost heater, defrost thermostat
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
If the heater and thermostat are ok itíll be the control Part 801 on diagram 10-Replacement parts for GE ESS22XGMCWW | AppliancePartsPros.com
  #3 (permalink)
Old 05-26-2009, 05:14 PM
Junior Member
Default locating
when i locate them, how do i check to see if they work? i do not know much about fridge's but is it not the defrost heater? how can i check to see f that could be the problem?
  #4 (permalink)
Old 05-26-2009, 05:45 PM
Hardcore DIY'er
APP Volunteer
Default
Follow the (how to) link in my previous post.
There may be some instructions in your user manual on how to "force" a defrost.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fridge seems fine, however, the freezer is not remotely cold or frozen ccs001 Refrigerator & Freezer Repair 0 09-19-2009 08:37 AM
back wall on the frezeer has frozen ice nelcrociti Refrigerator & Freezer Repair 0 01-27-2009 11:02 AM
Fridge not cold / Freezer not keeping stuff frozen Kaz Refrigerator & Freezer Repair 5 01-22-2009 10:20 AM
Freezer has frost on back wall, fridge not cold enough firfitr247 Refrigerator & Freezer Repair 7 12-02-2008 04:18 AM
Fridge & Freezer Cycle Cold To Warm Back To Cold terkel Refrigerator & Freezer Repair 1 09-25-2007 02:58 AM
