Discuss
Defrost thermostat
 in
Refrigerator & Freezer Repair
I have an old Sears refrigerator in need of a defrost thermostat(bypassing the thermostat fires up the heating element) The
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Defrost thermostat
  #1 (permalink)
Old 05-26-2009, 03:32 PM
RAS RAS is offline
Junior Member
RAS is on a distinguished road
Default Defrost thermostat
Brand: Sears   Age: More than 10 years
I have an old Sears refrigerator in need of a defrost thermostat(bypassing the thermostat fires up the heating element) The OE thermostat is an L70. made by FSP(?) Do all L70 thermostats have the same heat specs? You carry this thermostat AP3108444 which appears to be the correct shape but does not have color coded wires. The OE has one white, one brown. Does this matter? thanks
Ads By Google
  #2 (permalink)
Old 05-26-2009, 03:54 PM
Senior Member
applianceman is on a distinguished road
Default
This doesn’t make any difference at all I actually use the same thermostat for nearly every refrigerator I work on. Refrigerator Not Cooling Repair Guide
  #3 (permalink)
Old 05-26-2009, 05:20 PM
RAS RAS is offline
Junior Member
Default
Interesting, they do come in all sorts of heat ranges. After my post, I realized that the OE is stamped 10-74 on the back. Those numbers jive with the open/close temp numbers in F with that new L70.
Melt the ice, don't set the fridge on fire, guess it's not rocket science. If the OE opens @74F, the worst that'll happen with a lower temp version is an incomplete defrost.
thanks.
  #4 (permalink)
Old 05-26-2009, 05:42 PM
Senior Member
Default
I am not saying you should do this but I have been putting the 60-degree GE thermostat on just about all refrigerators for years now. It is always best to order the right part but I know from experience that in most cases if that thermostat is 60-degrees the coils will are defrosted. There are certain refrigerators that I will not do this on I am just talking generally.
  #5 (permalink)
Old 05-27-2009, 04:28 AM
RAS RAS is offline
Junior Member
Default
Sounds good.
I had another old Sears fridge in the basement collecting dust and snagged the thermostat. That was before I realized the temp range was right there and so did not even look. It seems to be working OK. 60F seems a good compromise. They're cheap enough. I'll probably pick up a new one even though the "spare" is working.
thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Defrost Thermostat msy Refrigerator & Freezer Repair 4 02-08-2010 08:19 AM
defrost thermostat Davis5000 Refrigerator & Freezer Repair 1 07-21-2009 12:20 PM
where is defrost thermostat located clintyboy Refrigerator & Freezer Repair 1 05-05-2009 07:11 PM
Defrost thermostat John Dulaney Refrigerator & Freezer Repair 8 11-02-2008 01:59 PM
Defrost Thermostat dgwolfe Refrigerator & Freezer Repair 4 03-15-2008 05:21 AM
