hello, I have maytag side by side, I get water that will leaks from the freezer at the bottom between the gasket and the freezer. I geta pretty good size puddle. I have noticed I will get ice buildup on floor of the freezer. when I have this water leak problem Ive noticed water coming from the grill opening on the bottom back wall of freezer. Im thinking possibly a draining problem when it defrost.What do you tkink, if this is the problem how do i go abot correcting thank you for your info.
