Discuss
Icemaker not doing anything
 in
Refrigerator & Freezer Repair
This morning the ice bucket was full of ice like water had overflowed the ice maker and flowed into the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Icemaker not doing anything
  #1 (permalink)
Old 05-23-2009, 04:07 PM
Junior Member
jmcdtucson is on a distinguished road
Default Icemaker not doing anything
Model Number: BCI20TW   Brand: Amana   Age: More than 10 years
This morning the ice bucket was full of ice like water had overflowed the ice maker and flowed into the bucket where it froze. Then it would make ice, but only teeny pieces. But at least the blades were turning.
I removed the icemaker and defrosted it and the inlet hose (it was blocked with ice). I re-installed it and now the icemaker does nothing. No water goes in and the blades don't turn when I lift the arm and put it back down. BTW I have removed and re-installed the ice maker several times in the past for other problems so I do know how to do it.
It's a modular type and I tested the thermostat resistance - looks right. I also tested the motor resistance and the warmer resistance. All seemed right.
Any pointers for troubleshooting from here before I buy a whole new one?
Ads By Google
Related Models
Amana BCI20TW Ref - Bottom Mounts
Amana BCI21V1C Ref - Bottom Mounts
Amana BCI21V1W Ref - Bottom Mounts
Amana BCI21VC Ref - Bottom Mounts
Amana BCI21VL Ref - Bottom Mounts
Amana BCI21VW Ref - Bottom Mounts
Maytag BCRE655 Range - S/c F/s Ele
Maytag BCRE683 Range - S/c F/s Ele
Maytag BCRE775 Range - S/c F/s Ele
Maytag BCRE805 Range - S/c F/s Ele
Maytag BCRE900 Range - S/c F/s Ele
Maytag BCRE905 Range - S/c F/s Ele
Maytag BCRE955 Range - S/c F/s Ele
Maytag BCRG800 Range - S/c F/s Gas
Maytag BCRG805 Range - S/c F/s Gas
Maytag BCRG860 Range - S/c F/s Gas
Maytag BCRG860A Range - S/c F/s Gas
General Electric BCS42CKB Refrigerator
General Electric BCS42CKC Refrigerator
General Electric BCS42EKB Refrigerator
General Electric BCS42ELB Refrigerator
General Electric BCS42ELC Refrigerator
General Electric BCS42ELD Refrigerator
General Electric BCS42UJB Refrigerator
Amana BD16E Ref - Bottom Mounts
Amana BD16LE Ref - Bottom Mounts
Magic Chef BDB420-1 Dishwasher - Undercounter
Magic Chef BDC420-1 Dishwasher - Undercounter
Magic Chef BDC520-1 Dishwasher - Undercounter
Magic Chef BDC620-1 Dishwasher - Undercounter
Magic Chef BDC720-1 Dishwasher - Undercounter
Magic Chef BDD520-1 Dishwasher - Undercounter
Magic Chef BDD620-1 Dishwasher - Undercounter
Magic Chef BDD720-1 Dishwasher - Undercounter
Maytag BDE110 Dryer - Ele
Maytag BDE210 Dryer - Ele
Maytag BDE212 Dryer - Ele
Maytag BDE303 Dryer - Ele
Maytag BDE312 Dryer - Ele
Maytag BDE313 Dryer - Ele
Maytag BDE4000 Dryer - Ele
Maytag BDE410 Dryer - Ele
Maytag BDE412 Dryer - Ele
Maytag BDE482 Dryer - Ele
Maytag BDE490 Dryer - Ele
Maytag BDE4910 Dryer - Ele
Maytag BDE510 Dryer - Ele
Maytag BDE512 Dryer - Ele
Maytag BDE590 Dryer - Ele
Maytag BDE5910 Dryer - Ele
Maytag BDE610 Dryer - Ele
Maytag BDE612 Dryer - Ele
Maytag BDE710 Dryer - Ele
Maytag BDE712 Dryer - Ele
Maytag BDE713 Dryer - Ele
Maytag BDE7400 Dryer - Ele
Maytag BDE7500 Dryer - Ele
Maytag BDE7600 Dryer - Ele
Maytag BDE7800 Dryer - Ele
Maytag BDE8000 Dryer - Ele
Maytag BDE8200 Dryer - Ele
Maytag BDE8300 Dryer - Ele
Maytag BDE8410 Dryer - Ele
Maytag BDE8420 Dryer - Ele
Maytag BDE8500 Dryer - Ele
Maytag BDE8600 Dryer - Ele
Maytag BDE882 Dryer - Ele
Maytag BDE9700 Dryer - Ele
Maytag BDE9800 Dryer - Ele
Maytag BDE9900 Dryer - Ele
Maytag BDG110 Dryer - Gas
Maytag BDG210 Dryer - Gas
Maytag BDG212 Dryer - Gas
Maytag BDG303 Dryer - Gas
Maytag BDG312 Dryer - Gas
Maytag BDG313 Dryer - Gas
Maytag BDG4000 Dryer - Gas
Maytag BDG410 Dryer - Gas
Maytag BDG412 Dryer - Gas
Maytag BDG482 Dryer - Gas
Maytag BDG490 Dryer - Gas
Maytag BDG4910 Dryer - Gas
Maytag BDG510 Dryer - Gas
Maytag BDG512 Dryer - Gas
Maytag BDG590 Dryer - Gas
Maytag BDG5910 Dryer - Gas
Maytag BDG610 Dryer - Gas
Maytag BDG612 Dryer - Gas
Maytag BDG710 Dryer - Gas
Maytag BDG712 Dryer - Gas
Maytag BDG713 Dryer - Gas
Maytag BDG7400 Dryer - Gas
Maytag BDG7500 Dryer - Gas
Maytag BDG7600 Dryer - Gas
Maytag BDG7800 Dryer - Gas
Maytag BDG8000 Dryer - Gas
Maytag BDG810 Dryer - Gas
Maytag BDG8200 Dryer - Gas
Maytag BDG8300 Dryer - Gas
Maytag BDG8420 Dryer - Gas
Maytag BDG8500 Dryer - Gas
Maytag BDG8600 Dryer - Gas
Maytag BDG882 Dryer - Gas
Maytag BDG9700 Dryer - Gas
Maytag BDG9800 Dryer - Gas
Maytag BDG9900 Dryer - Gas
Amana BDI16E Ref - Bottom Mounts
Amana BDI16LE Ref - Bottom Mounts
Maytag BDNS24A9-RA  Ref - SXS/I&W
Maytag BDNS24A9R  Ref - SXS/I&W
Maytag BDNS24A9RA  Ref - SXS/I&W
Maytag BDNS24A9RH  Ref - SXS/I&W
Maytag BDNS24F9  30" Electric Built - in Tap Touch Cooktop
  #2 (permalink)
Old 05-23-2009, 05:33 PM
Hardcore DIY'er
APP Volunteer
woodchuckie is on a distinguished road
Default
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube. It also could have stuck open and flooded your ice bin.
To eliminate the valve and water line as a problem Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear and with the water in the ice mold see if it starts cycling when it freezes and dumps the ice.
  #3 (permalink)
Old 05-23-2009, 09:19 PM
Junior Member
Default
More info:
I poured water into the mold manually and the machine made (and ejected) ice. So the water supply appears to be the problem. Maybe it is blocked or a valve is failing.
Can any one elaborate if the valve is on the outside back of the refrigerator/freezer somewhere? Or is it inside the freezer - maybe behind the false back of the freezer where the coils and defrost heater are?
BTW there is no water dispenser on this unit so I can't use that as a test.
Thanks.
  #4 (permalink)
Old 05-24-2009, 06:31 AM
Hardcore DIY'er
APP Volunteer
Default
The water inlet valve is located where the water supply enters the fridge on the back usually near the bottom.
Some people have rigged it and put voltage directly to it to get the same results. (IF YOU KNOW WHAT YOU'RE DOING.)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Icemaker jbasden Refrigerator & Freezer Repair 0 11-14-2009 06:05 PM
Icemaker Greg09 Refrigerator & Freezer Repair 0 11-03-2009 10:27 AM
Icemaker eep8v Refrigerator & Freezer Repair 1 08-17-2009 05:55 PM
icemaker pokealious Refrigerator & Freezer Repair 0 04-15-2009 12:29 PM
Ge Icemaker CURLY Refrigerator & Freezer Repair 0 03-06-2009 01:25 PM
