picklef16
#1 Posted : Saturday, December 15, 2007 11:13:44 AM(UTC)
picklef16
My ice maker stopped making ice several months ago. I thought it had to do with the R.O. system it was hooked up to, not enough pressure in the tank to fill the ice maker. I have since gotten a new R.O. system and it still wasn't making ice. Now I have it hooked directly to the water source and it is still not working. I was going to switch the ice maker line with the water dispenser line to see if it was getting water but they are different tubing sizes and it wouldn't work. Any suggestions would be appreciated.
picklef16
#2 Posted : Sunday, December 16, 2007 7:18:32 AM(UTC)
picklef16
I have read many threads on the forum that have the same type of problem with an ice maker not working but I'm not sure where to start troubleshooting. Can anyone help me out? I can't check the water inlet because the tubinh is two different sizes. Any other suggestions? Thanks,
kawfeeman
#3 Posted : Sunday, December 16, 2007 8:10:21 AM(UTC)
kawfeeman
ice maker line is 1/4" and the water line to the dispenser is 5/16" ... if you know how to cycle the icemaker you can remove the water line in the back of the refrige to the icemaker ... as the icemaker cycles it will close a contact to send 110vac to one of the solenoids of the water valve ( the one w/ the 1/4' plastic tube. ) you can test for 110vac at the two leads of the water valve for the icemaker .. you can also listen to see if the solenoid ( magnetic coil ) humms or not ... ( btw : you can also reverse the wires for the dispenser coil and the icemaker coil.. after reversing the wires, depress the water dispenser and see if you get water into the icemaker .. if you do the watervalve is good and the icemaker is definitely BAD.. ( also.. remember the icemaker will not cycle unless the temp in the freezer is < 8 degrees F ) ..... without enough cold, the icemaker will not cycle, even though water freezes at 32 deg F, icemaker needs to be colder .. hope this helps..
problem with no ice in bottom ice maker (Refrigerator & Freezer Repair)
by Daver032 11/29/2023 6:13:20 AM(UTC)
Maytag Frige 2014 no Ice & frige is 50 degrees (Refrigerator & Freezer Repair)
by Plus160 7/5/2023 5:05:07 PM(UTC)
No Ice No Water on LG LFX21960ST Refrig (Refrigerator & Freezer Repair)
by jvc57 3/3/2023 4:42:12 AM(UTC)
GE Cafe Refrigerator No Ice (Refrigerator & Freezer Repair)
by amappliancewi 2/8/2023 5:22:22 PM(UTC)
GE Fridge - no ice (Refrigerator & Freezer Repair)
by Guest 1/22/2023 8:39:51 AM(UTC)
Kitchen Aid 5 door - no ice (Refrigerator & Freezer Repair)
by charleskelleriv 10/31/2022 6:13:54 AM(UTC)
Whirlpool wrx735sdbe00 - Fridge warm no ice (Refrigerator & Freezer Repair)
by old_school33 6/10/2022 2:29:09 PM(UTC)
No Icecream at night - Freezer stops cooling around 8PM and everything is Frozen by 8AM. - (Refrigerator & Freezer Repair)
by usercraig 3/7/2022 7:40:11 PM(UTC)
Whirlpool Ice maker problems - no ice (Refrigerator & Freezer Repair)
by mphillips9im 7/17/2021 11:48:06 AM(UTC)
Replaced water inlet valve, still no ice or water (Refrigerator & Freezer Repair)
by Guest 7/3/2021 3:14:08 PM(UTC)
Samsung RS265TDRS Not Cooling/No Ice (Refrigerator & Freezer Repair)
by Guest 5/31/2021 10:09:58 AM(UTC)
GE Fridge model CFSP5RKBBSS - No Icecubes (Refrigerator & Freezer Repair)
by HaroldS 2/13/2021 2:17:30 PM(UTC)
** RESOLVED ** Subzero 590, no ice (Refrigerator & Freezer Repair)
by Intel1919 9/12/2020 9:54:24 AM(UTC)
8 yr old Whirlpool no ice & no water. Replacing filter every 2 months (Refrigerator & Freezer Repair)
by robodell100 9/5/2020 4:57:43 PM(UTC)
GE Profile Artica no ice but passes check (Refrigerator & Freezer Repair)
by phatcher 4/1/2020 2:01:31 PM(UTC)
