DAMON ROY
#1 Posted : Friday, May 22, 2009 2:36:42 AM(UTC)
DAMON ROY
Unit Won't Stop Cleaning !!
Checked Water Supply Ok
Checked And Cleaned Pump Ifs Ok
Let Stand Overnite Started Again Found 2 Or 3 Sheets Of Ice Pilled Up On Top Of Cutter. Removed Them Nfound Brocken Wire On Cutter.
Is It Possible To Fix Wire Myself?
Or Must I Replace Entire Assembly.
Many Thanks
TechnicianBrian
#2 Posted : Friday, May 22, 2009 10:07:08 AM(UTC)
TechnicianBrian
There is a restring kit for the cutting grid, but it is difficult to get it tight enough to properly cut. The entire grid comes as an assembly, but is well above the cost of the restring kit. So I guess the choice is your as to the direction you want to go. For assistance with part numbers, we would need a model number from the ice maker.
DAMON ROY
#3 Posted : Friday, May 22, 2009 12:53:27 PM(UTC)
DAMON ROY
I Ordered The New Assyl Thank You
TechnicianBrian
#4 Posted : Friday, May 22, 2009 12:57:51 PM(UTC)
TechnicianBrian
Glad I could help.
DAMON ROY
#5 Posted : Tuesday, May 11, 2010 1:33:33 AM(UTC)
DAMON ROY
seems like once a yeaar its something. Now it won't make ice seems to be stuck in harvest cycle
