Hi-My Roper fridge (model # RT14DKXJW00) isn't cooling while the freezer works fine. I took off the back panel and saw the evaporator fan was not working so with the model number, I obtained the part number and ordered a new evap fan motor from Appliance Pros. The problem now is that the new motor (2315539) doesn't have the same fittings as the old one. I can't see how it can be hooked up with the same wiring and fittings as the old one. I rechecked the part number based on the fridge model # and it seems to be correct. The number on the new motor matches, too. What am I missing? :confused: Thank you in advance! Tamara
