I came home to water trickling down the door under the ice/h2o dispenser. No ice in the icemaker. Frozen stuff well not frozen just cool. No problem noticed with refrigeration lines.Fridge seems ok. Freezer and fridge seem the same temp. Digital display is ok for freezer but is blinking 4 on the fridge.
I just installed a new diffuse and cam kit in my frig., but the freezer and frig are not getting cold all? Any suggestions on why?:confused:
Check the compressor in the back, if warm, but the condensing coils room temperature, your compressor is not running. You can try a new start device, but you will need the correct model #
