side by side has 3 drawers on lower refrigerator side. 2 of the drawers have digital controls for the temperature in the drawers.
One of the drawers is too cold. The display reads 25 degrees. If I push the "produce" button the display briefly changes to 34 degrees which is the correct set temp, then it changes back to 25 degrees.
Don't know if it is a coincidence, but the light that lights up the drawers went out about the time this problem started
thanks
Rick
