jesse livingston
#1 Posted : Saturday, May 16, 2009 11:34:58 AM(UTC)
jesse livingston
water leaking on the flood and in the frig. I defrosted the drain and no water leaking for the past few days, I shut the icemaker off. is there a adjustment for the water flow to the icemaker? what caused the drain to freeze up?
jesse livingston
#2 Posted : Saturday, May 16, 2009 11:44:46 AM(UTC)
jesse livingston
water leaking in the frig and on the floor. I defrosted the drain in the freezer and on leaks for three days. what caused the drain to freeze?
woodchuckie
#3 Posted : Saturday, May 16, 2009 2:11:17 PM(UTC)
woodchuckie
Your drain tube must be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
whirlpool range GS395LEG (Oven Repair (including Ranges and Cooktops))
by Guest Yesterday at 12:17:23 PM(UTC)
Whirlpool WRF757SDEM01 led light problem (Refrigerator & Freezer Repair)
by Guest 3/16/2024 1:02:12 PM(UTC)
Whirlpool WRS325SDHB08 Icemaker works intermittently (Refrigerator & Freezer Repair)
by donl1150 3/2/2024 5:04:55 AM(UTC)
Whirlpool Quiet Partner II Repair (Dishwasher Repair)
by Scubacrazy56 3/1/2024 7:54:50 AM(UTC)
Automatic water filter bypass - Whirlpool Refrigerator GD5SHAXLQ02 (Refrigerator & Freezer Repair)
by z-vap 2/28/2024 2:08:23 PM(UTC)
Whirlpool Gold GD5SHA Freezer Temperature Rises Overnight (Refrigerator & Freezer Repair)
by jrb98391 2/22/2024 10:20:17 AM(UTC)
Whirlpool wtw4815ew1 Black Residue/Marks and Shaking Violently (Washer Repair)
by crvtec 2/14/2024 5:05:43 PM(UTC)
Whirlpool Cabrio WTW6300SW1 (Washer Repair)
by Fieldsafo 2/12/2024 4:00:47 PM(UTC)
Whirlpool french door w/ bottom freezer (Refrigerator & Freezer Repair)
by JumperWire 2/11/2024 1:41:25 PM(UTC)
whirlpool washer model WFW6620HW2 Fried? (Washer Repair)
by justme56 2/11/2024 8:42:17 AM(UTC)
Whirlpool Oven WFE770H0FZ2 (Oven Repair (including Ranges and Cooktops))
by Guest 2/9/2024 7:03:09 AM(UTC)
Whirlpool Duet Washer - Possible Faulty Fill Valve (Washer Repair)
by Guest 2/2/2024 4:18:21 PM(UTC)
Whirlpool heat pump dryers (Dryer Repair)
by Aptmtncguy 1/19/2024 3:44:50 PM(UTC)
Whirlpool Gs6SHAXML00 (Refrigerator & Freezer Repair)
by shelbast20 1/17/2024 5:58:47 AM(UTC)
whirlpool wfg510s0ab2 oven not lighting (Oven Repair (including Ranges and Cooktops))
by sparktender 1/15/2024 1:43:04 PM(UTC)
