talktomeh
#1 Posted : Thursday, May 14, 2009 3:52:32 PM(UTC)
talktomeh
I Have a GE Side by Side purchased 2004. My sister has the same frig purchased the same time, both friges a are doing the same thing.
The freezer is freezing up causing the frig to warm. Today I replaced the Main control board, the defrost heater and the defrost themastat costing $175.oo. My question is, can we get away with just changing the heater and thermastat in the other frig or will the main board cause the new heater to go out, that is what I was told. Is there a simple way to check the main control board. The friges have been doing this for about a year, what we do is just take everthing out of the freezer and unplug the frig for about 24 hour or so, and than the frig will work fine for about 2 months. Thanks,
Mary
woodchuckie
#2 Posted : Thursday, May 14, 2009 4:36:50 PM(UTC)
woodchuckie
The cheapest way is just to replace the defective part. defrost heater, defrost thermostat. See how here. Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
If the heater and thermostat are ok it’ll be the control.
talktomeh
#3 Posted : Thursday, May 14, 2009 9:04:16 PM(UTC)
talktomeh
I will replace the heater and the thermostat, but it the main board is not working proberly will it burn out the new heater?
woodchuckie
#4 Posted : Friday, May 15, 2009 4:22:02 AM(UTC)
woodchuckie
If the heater and defrost thermostat are not bad they don't need to be replaced. Did you test them.
No the board won't cause other parts to go bad.
judie29
#5 Posted : Friday, May 15, 2009 12:17:24 PM(UTC)
judie29
Found evaporator froze up. Test defrost system found defrost thermostat closed all the time. Replace defrost thermostat after
5 days system froze back up. Appliance company said to replace
mother board. Replaced the mother board nothing worked. Took
board back gave another and that system came up running motor
in freezer will only turn in slow speed. Put old mother board back
in , motor is turning up to speed but old board does not defros.
Board appliance company gave to replace mother board is Model
WR55X10656. Now they say motor need to be replace in freezer
but motor works good with old board but old board will not defrost
any suggestions what to do????????
woodchuckie
#6 Posted : Friday, May 15, 2009 1:09:06 PM(UTC)
woodchuckie
Did you test the defrost heater. It will not defrost if the heater doesn't work.
The defrost thermostat should be closed unless it is warm.
judie29
#7 Posted : Friday, May 15, 2009 2:10:17 PM(UTC)
judie29
We replaced the thermostat also and the heater is working.
Amana Freezer Freezing Up (Refrigerator & Freezer Repair)
by Shinnymoon 2/25/2017 10:50:31 AM(UTC)
frig vents from freezer freezing up (Refrigerator & Freezer Repair)
by daveshelp 10/2/2012 5:58:39 AM(UTC)
Coils behind freezer freezing up solid (Refrigerator & Freezer Repair)
by Benlampo 5/9/2011 6:14:58 AM(UTC)
Coils Inside Bottom Mount Freezer Freezing Up (Refrigerator & Freezer Repair)
by VS828 3/14/2011 8:16:37 AM(UTC)
Freezer freezing up and no air blowing to refrig (Refrigerator & Freezer Repair)
by cinti 5/22/2008 6:36:07 PM(UTC)
