The fridge is actually a Dometic in a travel trailer. I clicked Crosley just so I could continue. There is an air flap from the freezer to the fridge to control the fridge temp. This appears to be working fine yet everything in the fridge freezes even with the flap closed as much as possible. Thermostat problem? Do you carry Dometic parts? Thanks, Dan
