| » Warm refer. |
Model Number: et18ukxan00 Brand: Whirlpool Age: More than 10 years
My refrigerator will only cool down to 50 degrees when turned to max cool. The Freezer works fine. I noticed that the 2 vents in the ceiling of the refrig. were filled with ice, so I turned it off and took the backing in the inside of the freezer apart. You know where the fan and thermostat bulb are. The whole thing was a block of ice. After cleaning all of the ice off and thawing it out, I put it back together. Then the refer. would freeze everything at the warmest setting , now the ice is back and it's only cooling down to 50 degrees on the coldest setting again. Please help
Related Models |
Replacement parts for WHIRLPOOL ET18UKXAN00 | AppliancePartsPros.com Here is a wiring diagram https://www.servicematters.com/docs/...%202159549.pdf Sounds like a defrost problem. Remove the evaporator coil cover. Force the unit into a defrost cycle, see the wiring diagram. If the heater heats up then odds are high you need a new defrost board. Be careful do not burn your fingers. Note: the defrost thermostat must be frozen as it turns power off to the heater just above freezing. If it does not heat up check the defrost thermostat, should be 0 ohms when frozen and the defrost element/heater usually around 20 ohms. Below is a good link with additional help. Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
__________________
| Display Modes | |
| Freezer to warm refer fine | e63 | Refrigerator & Freezer Repair | 3 | 02-22-2010 02:03 PM |
| wet refer | Brucefamily | Dishwasher Repair | 1 | 09-11-2009 06:46 AM |
| Freezer Freezing Refer Warm | carvelli | Refrigerator & Freezer Repair | 6 | 08-25-2009 07:04 AM |
| Typical cold freezer, warm refer problem | farmey | Refrigerator & Freezer Repair | 7 | 06-26-2009 04:47 PM |
| refer quit | stan avis | Refrigerator & Freezer Repair | 1 | 02-18-2009 04:03 PM |
