| » kenmore fridge |
Model Number: 10676239400 Brand: Kenmore Age: 5 - 10 years
the frige part is not keeping cool freezer seems ok can you help I think it is the thermostat if so is there a step by step instructions to replace
thank you andy Ads By Google Related Models |
Replacement parts for KENMORE 10676239400 | AppliancePartsPros.com Check your freezer temperature, it should be between 0 and 5 degrees F. If the unit seems to be cycling correctly then it may be a thermostat problem. Of perhaps the mechanism that opens/closes the damper which regulates the amount of cold air entering the fresh food section is no good. If the compressor runs continuously. Check that the evaporator fan is running. It is required to push cold air into the fresh food section and efficiently cool the air in the freezer. Remove the cover inside the freezer so you can inspect the evaporator coils. If they are heavily iced/frosted over you have a defrost problem. If little or no frost on them you may have a sealed system problem.
__________________
| Display Modes | |
| kenmore fridge | ed c | Refrigerator & Freezer Repair | 1 | 07-15-2011 12:34 PM |
| Kenmore fridge leaks water into fridge instead the drain tube | skg | Refrigerator & Freezer Repair | 5 | 08-14-2009 04:57 AM |
| kenmore fridge | dccmw | Refrigerator & Freezer Repair | 3 | 01-26-2008 05:35 PM |
| Kenmore Fridge | rjohnson | Refrigerator & Freezer Repair | 2 | 01-14-2008 07:16 PM |
| Kenmore fridge - water drips into fridge | njblue55 | Refrigerator & Freezer Repair | 3 | 08-07-2007 07:50 PM |
