jrbb1111
#1 Posted : Tuesday, May 12, 2009 5:56:17 AM(UTC)
jrbb1111
My Amana side-by-side sporadically will stop cooling.
Last night it stopped cooling but the condensor fan was running. What's weird is that the door water will stop working about the same time. If you push in the lever you can hear a slight buzz but no water (the ice dispensor and cavity light still work).
The compressor was hot to the touch but not running (you could touch it, but uncomfortable to leave your hand on it for more than a few seconds). Condensor coils felt room temperature (when it's cooling the condensor coils feel slightly warm).
I rotated the defrost timer and at the first click the condensor fan will stop (assuming this is in defrost mode). Rotate it about another 30 degrees and it clicks again the condensor fan comes on. Last night I did this twice and it started cooling again.
Have not verified the coils are frozen...I'm a newbie and couldn't/didn't see them after removing the back bottom cover, and just pulled the diagrams this morning to understand where everything is so I will check them tonight. Partially suspect if the coils freeze it could cause the water line to freeze (which goes up to a filter located at the top inside of the refrig?).
The condensor coils need cleaning...dust and dog hair covering the inside but how do you get to the inside (upper and lower grid, the build-up in the middle of them).
Advice on what I should look for or check first?
woodchuckie
#2 Posted : Tuesday, May 12, 2009 7:42:02 AM(UTC)
woodchuckie
I would check the compressor overload relay for the compressor issue. Part 211 on this diagram. http://www.appliancepartspros.com/sect/9/x/g/9xgihfdjjf.gif
How to test here-Refrigerator Repair Guide: How To Test the Compressor Relay - ACME HOW TO.com
To clean the condenser coils, compressed air will work but messy with all that dust in the air. See if you can access them from the front after taking the kick plate off. I use one of those brooms made for a ceiling fan. It's kind of flat. One of those duster things with a handle might work.
I won't speculate on the water till you get the compressor issue settled.
jrbb1111
#3 Posted : Tuesday, May 12, 2009 9:06:55 AM(UTC)
jrbb1111
I've done some more searching and found somebody with a similar problem on basically the same model. The issue was the defrost thermostat was bad and not allowing the fan to come on consistently, which let the evaporater freeze up and also the water line. Of course the condensor being really dirty would cause the compressor to run more also.
Wondering if the compressor is running more to try to compensate for one or both issues above and causing the overload to kick off?
I think this is what I will do:
1. clean condensor good
2. take a look at the evaporator to see if frozen up, and inspect defrost thermostat
3. if #2 looks good, test the overload relay
Thanks for your replies. This is helping me understand how everything works better.
jrbb1111
#4 Posted : Thursday, May 14, 2009 7:03:09 AM(UTC)
jrbb1111
Condensor was nasty, I know it hadn't been cleaned in 8-9 years. Hard to get to so wind up blowing it out with an air gun with the shop vac running behind the condensor fan. The next morning it wasn't working...food was not warm but definitely not as cold as it should have been. Door water dispenser not working.
Defrost timer appeared to function fine. Rotate it to defrost and the condensor fan would stop, and about 20-30 minutes later it would click and the condensor fan would start up...but no compressor or evaporator fan.
Pulled the timer and check it with a multimeter. When I touched the common terminal (#3) and the others it would periodically quickly flash a number than go to open circuit. Tried touching other terminals (1-2, 2-4) and they showed continuity correctly (one set for defrost, other for cool). Have the wiring diagram which shows a resistor at the common terminal, so maybe that causes the continuity to not show up with my multimeter. Anyway, plugged the timer in and it shows 120V across the common and appropriate other terminals pending which position you have it on.....determined it was good.
Pulled the inside cover off the freezer to inspect the coils. Only about the top 1/4 of the coils had a light/moderate frost on them (the compressor hadn't been running, and then the unit was unplugged for awhile now). Set time to defrost and the heater (definitely hot) came on and melted the remaining frost.......heater must be good. Turned the timer back to cool and the compressor kicked on and evap coils started to frost, after about a minute the evap fan kicked on.
**A couple minutes later the water dispensor started working......was it frozen in the door and just defrosted??
Turned the freezer temp control all the way off, evap fan and compressor stoppped. Turned it back on and everything started back up.
Unplugged it again and pulled the defront t-stat out to test. Had a reading of around 240 (believe it said "k" ohms). Physically it looked fine so it was reinstalled. Determined this was good.
Let it run on cool for probably an hour (inside cover off, door shut) periodically checking it. Evap got a decent coating of frost on it but didn't look frozen or anything.
Turned freezer and frig temp control all the way down to "1" and it continued to run (compressor and evap fan) for at least an hour. Ran out of time and wanted to put all of the freezer food back in, so reinstalled back cover, put in food, and reset temp control to "5" (scale is 1-7...5 is what we have used for years). Shut the door and left it alone, briefly opening them to get food out for dinner and a couple of other times. Compressor and evap fan continued to run at least another 6 hours solid (I went to bed), but it was cooling nicely it seemed.
This morning nothing was running at first, everything was cold/frozen as it should. A minute later it kicked on (compressor/evap fan) as normal.
Door water still working.
At this point waiting to see if the issue returns. The only thing I truly changed was cleaning the condensor. Hoping the dirty condensor was making the compressor run longer/harder to keep cool (though we have never needed to change the temp. control for years) and thus kicking out the overload. Wife did verify that the frig was possibly colder than normal this morning.
jrbb1111
#5 Posted : Tuesday, May 19, 2009 4:13:43 AM(UTC)
jrbb1111
Okay, so it had been working fine for over a week but this morning the condensor fan was running but no cooling (no evaporator fan or compressor) and the ice was starting to melt...........and of course the door water is not working. Speaking of the water, after looking at the wiring diagrams and such it doesn't look like it is related in anyway to the compressor/evaporater issue but everytime it stops cooling the door water stops!
Refrig not cooling but freezer is (Refrigerator & Freezer Repair)
by allofus00 11/13/2015 5:24:29 AM(UTC)
Frig not cooling at all (Refrigerator & Freezer Repair)
by jbill1918 7/16/2015 11:20:10 AM(UTC)
Hotpoint Frig not cooling, already replaced mainboard, heater and thermostat (Refrigerator & Freezer Repair)
by merc0230 8/27/2014 2:54:24 AM(UTC)
Refrig not cooling. (Refrigerator & Freezer Repair)
by jpskins 7/23/2014 4:24:01 PM(UTC)
Hotpoint frig not cooling (Refrigerator & Freezer Repair)
by merc0230 6/22/2013 10:56:45 AM(UTC)
Freezer and Frig not cooling (Refrigerator & Freezer Repair)
by frigadare 10/2/2012 7:58:47 AM(UTC)
Freezer & Frig not cooling (Refrigerator & Freezer Repair)
by missalive 9/17/2012 7:02:17 AM(UTC)
by dz1966 6/27/2012 12:58:42 PM(UTC)
Roper frig not cooling (Refrigerator & Freezer Repair)
by Charles Wilson 5/16/2012 5:08:30 PM(UTC)
Refrig not cooling and air comes from return? (Refrigerator & Freezer Repair)
by Cupdog 4/11/2012 2:54:28 PM(UTC)
Refrig not cooling (Refrigerator & Freezer Repair)
by jjpowe2 11/27/2011 6:23:41 AM(UTC)
Amana Frig not cooling, but freezer works (Refrigerator & Freezer Repair)
by drewbenson 10/13/2011 8:24:23 AM(UTC)
GE Profile side by side refrig not cooling (Refrigerator & Freezer Repair)
by j4son 9/22/2011 10:53:34 AM(UTC)
KitchenAid Superba Refrigerator Freezer & Frig not cooling (Refrigerator & Freezer Repair)
by dsmit10 9/3/2011 10:11:20 AM(UTC)
freezer and frig not cooling???? (Refrigerator & Freezer Repair)
by pmase123 7/23/2011 7:18:56 AM(UTC)
