door water...very slow, ice cubes..very small Changed water valve on back, checked filter...when I push door water switch, water sprayed good into glass under filter. Could it be frozen lines or some other clog? When I say door water slow, I mean 2 minutes or more to fill a glass.
Friend came over, showed me the other water valve that has 2 lines going to ice maker and door water. Guess i wasted the 50 bucks on the main water valve! At least I didnt buy a new filter! Thanks anyway guys! Steven:)
Originally Posted by: steven barnaby Friend came over, showed me the other water valve that has 2 lines going to ice maker and door water. Guess i wasted the 50 bucks on the main water valve! At least I didnt buy a new filter! Thanks anyway guys! Steven:)
