kmoskow
#1 Posted : Monday, May 11, 2009 3:02:46 PM(UTC)
kmoskow
unable to remove wire going into heater connector - what is the trick, tried pulling it out but no luck:mad:
woodchuckie
#2 Posted : Monday, May 11, 2009 3:37:18 PM(UTC)
woodchuckie
It may be corroded. Try to wiggle it side to side to loosen it. Some liquid wrench like you use to get nuts loose might help.Let it soak awhile.
You may have to put a new connector on and crimp it to put the new heater on.
