Good Day All,
Working on a Frigidaire FRT21HR6A with a compressor problem. Already Replaced the run capacitor and start relay without results. Problem still is the compressor does not stay on. Upon the initial power-up - compressor buzzes/runs louder than usual and shuts off after 10-15 secs. The cycle will continue if left on but no start. The terms on the compressor all seems the same - pegging a 1 ohm setting but all in the 1.5 range on a 10 ohm meter.
Thanks in advance for the opinions.
THIS FORUM IS DEAD!!!!!!! |
Thanks for the links, most likely will end in a trip to Best Buy.
