wallfishing
#1 Posted : Saturday, May 9, 2009 6:08:30 PM(UTC)
wallfishing
As usual, my kenmore just went out of warranty so now it is up to me to fix the ice dispenser. The unit is a side by side with the dispenser in the door. The water dispenser works. The ice maker works as well but when one depresses the ice dispenser lever, nothing happens. I first noticed it and tapped the lever a few times and the motor kicked in but now nothing happens when you depress the lever. I figure it is either the lever switch or the dispenser motor. I am looking for help in isolating what needs to be repaired. I already have the motor out of the door but it is a DC motor so not sure how to test it. I appreciate any suggestions on how to proceed. Thanks in advance.
woodchuckie
#2 Posted : Sunday, May 10, 2009 7:20:44 AM(UTC)
woodchuckie
You could use a 12 volt car battery or charger to put DC to it. Since moving the switch worked once, it's probably the switch.
wallfishing
#3 Posted : Sunday, May 10, 2009 9:11:39 AM(UTC)
wallfishing
Good idea on the car battery. Unfortunately, the motor is 120volts DC, it uses a rectified AC current. I agree that it sure seems like the switch. I think I will pull it and test it for continuity.
wallfishing
#4 Posted : Sunday, May 10, 2009 10:59:47 AM(UTC)
wallfishing
As I started to take the dispenser apart I noticed that the hinge holding the despenser door in place was broken. Thus the door was sliding off the hinge rather than pivoting. As a result, the door could not activate the switch properly. The switch and motor were in working order. The hinge is plastic so I used some super glue to resecure the hinge and it appears to be working well. Now all I have to do is make sure people don't push down on the ice despenser so hard that they break the hinge again. Thanks for the help.
Whirlpool Ice Dispenser Auger will not run (Refrigerator & Freezer Repair)
by WhirlpoolDave 4/1/2024 12:44:26 PM(UTC)
KitchenAid KSSP42QTS00 Ice dispenser leaking (Refrigerator & Freezer Repair)
by sternern 3/20/2024 2:21:47 PM(UTC)
Door Ice dispenser not functioning properly (Refrigerator & Freezer Repair)
by abennet4@comcast.net 12/6/2023 4:45:55 PM(UTC)
Amana AFI2538AEB refrigerator ice dispenser door opens and closes continually (Refrigerator & Freezer Repair)
by Guest 9/30/2023 6:59:28 AM(UTC)
Ice dispenser light on Frigidaire FGHC2342LF3 not working (Refrigerator & Freezer Repair)
by parkerfly 9/2/2023 10:27:54 AM(UTC)
Whirlpool Ice Dispenser Auger issue (Refrigerator & Freezer Repair)
by Daveh839 7/11/2023 11:36:45 AM(UTC)
how to determine if kenmore ice dispenser is bad (Oven Repair (including Ranges and Cooktops))
by Guest 7/6/2023 3:32:28 PM(UTC)
Frigidaire water/ice dispenser issue FFHS2322MSKA (Refrigerator & Freezer Repair)
by Guest 6/4/2023 10:21:19 PM(UTC)
Ice dispenser freezing (Refrigerator & Freezer Repair)
by jesus freak 1/22/2023 11:25:08 PM(UTC)
Ice Dispenser on Frigidaire side by side pulses when dispensing ice (Refrigerator & Freezer Repair)
by JordanNolan 1/8/2023 8:50:08 AM(UTC)
GE side-by-side water/ice dispenser stops working during defrost (Refrigerator & Freezer Repair)
by pvsherman 12/18/2022 11:23:17 AM(UTC)
Whirlpool Ice Dispenser loud (Refrigerator & Freezer Repair)
by jbusbee83 7/25/2022 3:46:45 PM(UTC)
Ice dispenser condensation (Refrigerator & Freezer Repair)
by Guest 6/16/2022 10:57:08 AM(UTC)
Frigidaire FRS6LF8FS1 ice dispenser not dispensing ice (Refrigerator & Freezer Repair)
by BradASchreiber 5/31/2022 10:45:28 AM(UTC)
Water/ice dispenser funnel won’t retract (Refrigerator & Freezer Repair)
by Guest 2/5/2022 1:15:16 PM(UTC)
