The refrigerator door will not close automatically.
My ge refrigerator door has stopped closing automatically. Is there something I can do to fix this problem?
Here are your parts. The listed model number seems to be short a couple digits so I hope all the parts in the models listed are the same. Replacement parts for TFX22R models | AppliancePartsPros.comFirst check that the unit is still level or leaning slightly towards the back, just in case a support roller has broken. If OK check the cam assemblies on the bottom hinge of the door. One on the door Item 16 in Section 1 and one on the hinge Item 451 in Section 3. Click on their pictures in the parts fore more/better views. The door actually rides up and down on these cams. When closed it is on the down side of the cam so gravity holds the door closed. |
THIS FORUM IS DEAD!!!!!!! |
