could someone tell me if my problem is relay or thermostat, when i turn the thermostat all the way off and then back on ,i can hear the compressor come on for a few seconds
Here are your parts, includes a wiring diagram. Replacement parts for MSD2142AR models | AppliancePartsPros.comI am assuming that the compressor then continually tries to start but cannot. It could be either part you list. You have to do more troubleshooting. Following is a good link with info on how to check things. Note: that if the compressor checks out OK electrically it does not eliminate it as the cause as it may have mechanical problems. Appliance Repair Guide: How To Fix a Refrigerator - ACME HOW TO.comThe capacitor can be checked if it is shorted or not taking a charge. The problem is that it cannot be checked with actual working voltage and they can fail when 120 volts is applied to them. Note: That they are very reliable. |
THIS FORUM IS DEAD!!!!!!! |
