I got this fridge for free but neither side will get cold.I tried to take it aprt and find anything clogged but no luck. when i took the frezzer section apart i found that the evap fan does not come on. the coils are not cold at all. the fan in the back is working and so is the condenser. any tips would be greatly appreciated.
[COLOR="DarkRed"]the fan in the back is working and so is the condenser[/COLOR] If by "condenser" you mean the compressor then you have a sealed system problem and it will be an expensive repair. You can usually hear it running also it should be warm and you should be able to feel it vibrating.
The evaporator fan may be another separate problem. |
THIS FORUM IS DEAD!!!!!!! |
