| » GE stopped working |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: gss25jemb bb Brand: GE Age: 5 - 10 years
Stopped cooling/freezing, found evap coil clogged with lint, cleaned but no help, fan running -no comp
thxs |
Go to the back of fridg and remove motherboard cover. Turn off power and remove J8,J9, J11 common connector. Stick a jumper wire in connector pins J11 and J8, plug in fridg, compressor should run. If so, replace motherboard and evaporator fan and thermistor. If no run, pry off the start relay from the side of the compressor and order a new one. If you have a meter it would help to confirm voltage to the compressor.
Good luck on this sorry excuse for a fridg.
__________________
Hi Richappy:
Thanks for your reply. I did what you said and jumpered J8 and J11 and the compressor started to run. Its pretty quiet so I put my hand on it and could feel it running. Also checked for power at the comp and it was zero. Both fans are running so would I still have to replace the evap fan? Thanks a bunch York |
| Display Modes | |
| maytag ice maker stopped working | Cope | Refrigerator & Freezer Repair | 0 | 10-30-2007 04:45 PM |
| Ice Maker Stopped Working | banluc | Refrigerator & Freezer Repair | 2 | 09-25-2007 06:28 PM |
| ice maker stopped working | pavelj539 | Refrigerator & Freezer Repair | 0 | 09-23-2007 03:33 PM |
| Kenmore Dryer Stopped Working | Rob | Dryer Repair | 4 | 09-19-2007 07:23 PM |
| Ice Maker Stopped working | Judymike08@yahoo.com | Refrigerator & Freezer Repair | 1 | 08-26-2007 07:56 AM |
