djneil1
#1 Posted : Friday, October 21, 2011 9:01:28 AM(UTC)
djneil1
I am not getting water to my icemaker but am getting water through the door. I removed the water filter and checked for any clogged lines. Then I replaced the dual fill valve. Still no water to the icemaker. The optical sensor appeared to be giving the correct indications that it is working properly based on what I have seen on other posts regarding how to check if it is operating correctly. I am thinking my next step is replacing the icemaker itself....can someone please confirm that this is a logical next step??? Perhaps I am overlooking some other simple troubleshooting I could perform first. Thanks in advance for any tips/help/assistance.
#2 Posted : Saturday, October 22, 2011 3:25:22 AM(UTC)
Swap the water solenoid connectors and have someone press the water fountain. If the solenoid hums, but no water, you have a frozen water line.
djneil1
#3 Posted : Saturday, October 22, 2011 5:25:34 AM(UTC)
djneil1
Thanks for the advice but when I replaced the fill valve, I made an effort to check my lines. I disconnected the tubing at the back of the fridge and poured a small amount of water into the tube and I was able to blow it all the way into the tray. I have gone ahead and ordered a new icemaker (from this site) and if that doesn't do the job, I'll certainly swap out those connectors. Thank you.
djneil1
#4 Posted : Monday, October 24, 2011 3:20:08 AM(UTC)
djneil1
Swapped out the icemaker itself and we are back in business.
