Register | FAQ's | New Posts | Today's Posts | Extras |
» Does my Maytag have a defrost timer or adaptive defrost control? Where is it? |
![]() Model Number: MSD2351HEB Brand: Maytag Age: 1 - 5 years
![]() I have a Maytag MSD2351HEB. It will be 2 years old in August. I read the post about a faulty defrost system, but then I read other posts about having an adaptive defrost control...so now I'm confused. The freezer still seems cold enough, but the fridge is not. There is frost on the back wall of the freezer. What and how do I check this??? Please help...(and speak in layman's terms, please). I've got 8 kids and 6 gallons of milk depending on me...lol ![]() Brandy Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Quote:
Check the defrost heater and defrost thermostat first. Your user manual or the tech manual behind the kick panel at the floor on the front may tell how to test these parts, also See how and where here. Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com If those parts are ok you problem is the adaptive defrost control. Part 12 on the diagram of your controls here. Replacement parts for MAYTAG MSD2351HEB | AppliancePartsPros.com |
![]() Remove the back inside of the freezer. You'll see the iced up coils. The thermostat is clamped to the coils. The heater is under or woven thru the coils.
Part 3 and 7 on diagram 6. Replacement parts for MAYTAG MSD2351HEB | AppliancePartsPros.com Last edited by woodchuckie : 05-06-2009 at 04:24 PM. |
![]() I've defrosted the coils w/ a hair dryer. I unclamped the thermostat but do not see a way to test it with a continuity tester..? I tested the heater with a continuity tester and got nothing. My husband also tested the capacitator on the compressor with the continuity tester and nothing on it either. Should the capacitator show anything on the continuity tester? And is there anyway to test the thermostat w/o cutting the wires. The wires are harnessed in with a bunch of other wires and go into the back of the freezer where I can't see them.
![]() I don't know of a way if the manual doesn't tell. I would turn the power off and cut the wires. you can twist them back together with a connector.
You shouldn't be messing with the capacitor. It's involved with the compressor. If you didn't get anything on the heater then it's bad. |
![]() I replaced the defrost heater a little over a month ago and it has been working great since then....that is, until yesterday. I noticed the fridge wasn't quite as cold as it had been. I checked inside the back of the freezer and yep...frosting over again...I thawed it all w/ a hair dryer...but it is steadily frosting back over....What next?
![]() The defrost system consists of the three parts discussed in earlier in this thread. One could have gone bad again or the adaptive defrost control could be acting up and not working all the time.
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Manually Cycle Adaptive Defrost Control | DIYRob | Refrigerator & Freezer Repair | 4 | 03-20-2012 09:43 PM |
I still have froze in the freezer after changing defrost timer & bi-metal defrost | matteson | Refrigerator & Freezer Repair | 0 | 12-29-2009 06:25 PM |
Freezer Thermostat or Adaptive Defrost Control?? | bet_now | Refrigerator & Freezer Repair | 2 | 06-20-2009 01:24 PM |
Adaptive Defrost Control | jedwards | Refrigerator & Freezer Repair | 7 | 10-04-2008 03:47 AM |
Adaptive Defrost | hdebby | Refrigerator & Freezer Repair | 0 | 05-31-2008 10:03 AM |
