Water Keeps Pouring Out After You Release Lever. What Could This Be?????
It will either be a sticking switch, or a bad water valve. If it's the valve, replacement is the answer. You can test for the valve by removing the electrical connector from the valve in the back of the refrigerator, and momentarily applying 120VAC to the terminals of the side you want to test. Have someone up front watching (and catching the water in a cup (make sure he doesn't activate the switch). If water continues to flow after you remove the "test voltage", the problem is in the valve. Part number: AP3103466
