patpappym@bandwagon.net
#1 Posted : Monday, May 4, 2009 10:30:54 AM(UTC)
Having problem with freezer coils freezing. It is as if I'm not getting any power to the defrost coil. In sevice mode 1 it shows that the defrost
thermostat in the shorted position.To me that shows that power should be
going through the defost coil and it 's not. Does this mean I need a new control panel?
#2 Posted : Monday, May 4, 2009 6:34:51 PM(UTC)
The first thing I would do is check the defrost heater (#15 on the diagram) for continuity.
If there is nothing wrong then replace the control board (#5 on the diagram)
Here are the breakdown diagrams and Replacement parts for MAYTAG MBF2256KEQ | AppliancePartsPros.com
#3 Posted : Tuesday, May 5, 2009 6:39:00 AM(UTC)
Gene I put the refrigerator in forced defrost and it did defrost the coil. Then the thermostat did show open in the service mode 1. So then it would be the control panel correct? I don't quite understand pin 3 function on terminal board j1. It says d-sense does that mean defrost sensor and how does it work?
Subzero 650 Control Panel (Refrigerator & Freezer Repair)
by kbf99 2/14/2024 5:06:04 AM(UTC)
Control panel goes dark and loud clicking noise (Refrigerator & Freezer Repair)
by Guest 2/6/2024 12:57:10 PM(UTC)
Control panel for GE Spectra Stove Model # JBP79WB4WW (Appliance Parts)
by janieben@rainbowtel.net 1/22/2024 5:16:12 PM(UTC)
LG LFXS28968S /00 control panel removal (Refrigerator & Freezer Repair)
by Guest 11/15/2023 5:36:56 PM(UTC)
Whirlpool Control Panel VOM Testing (Washer Repair)
by Guest 10/19/2023 10:23:21 AM(UTC)
Kenmore Elite Refridgerator control panel not working (Refrigerator & Freezer Repair)
by Guest 10/3/2023 10:18:35 AM(UTC)
LG control panel issue (Dishwasher Repair)
by Guest 9/10/2023 7:18:58 AM(UTC)
removing cooktop control panel on LG double oven (Oven Repair (including Ranges and Cooktops))
by Hurdles 4/4/2023 11:41:26 AM(UTC)
Jenn air double wall oven control panel problems (Oven Repair (including Ranges and Cooktops))
by Guest 2/2/2023 3:45:53 AM(UTC)
Dispenser control panel is dead (Refrigerator & Freezer Repair)
by Expat 1/21/2023 1:56:42 PM(UTC)
Kitchenaid Control panel melted (Dishwasher Repair)
by Guest 12/9/2022 2:41:47 PM(UTC)
Whirlpool WRF555SDHV refrigerator dispenser control panel (Refrigerator & Freezer Repair)
by janinePR 12/8/2022 2:17:23 PM(UTC)
GE GSS25WGTGBB - Control panel dies when turning on dispenser light (Refrigerator & Freezer Repair)
by noparts 9/19/2022 6:17:40 AM(UTC)
Maytag MHWE300VW00 Control Panel shuts off, then on, then off... (Washer Repair)
by ab2112 8/1/2022 10:00:14 AM(UTC)
GE frig Control Panel replacment procedure (Refrigerator & Freezer Repair)
by whkendri 4/27/2022 6:41:50 AM(UTC)
