| » connecting water line to ice maker |
Are you talking about the main water supply which hooks to the water inlet valve at the bottom on the back of the unit.
Or are you talking about the line going from the water inlet valve up the back of the unit where it hooks to a junction and goes through the back to the ice maker. It doesn't actually connect to the ice maker. The water goes into a fill tube and just flows into the ice mold per gravity. |
Quote:
Quote:
This diagram shows threaded connectors to screw onto the inlet valve. Most ice maker kits will have the proper fitting with it. Some have a self tapping valve you clamp to the water source and has a fitting for a coil of tubing. Replacement parts for AMANA SRD22S3W | AppliancePartsPros.com
| Display Modes | |
| Water line to ice maker keeps freezing up | ecbtab | Refrigerator & Freezer Repair | 1 | 03-29-2012 02:02 PM |
| Water line works but Ice Maker does not | JaxInvestor | Refrigerator & Freezer Repair | 0 | 01-12-2010 06:37 AM |
| ice maker water line leak. | MRNDAD | Refrigerator & Freezer Repair | 1 | 03-23-2009 05:14 PM |
| Water Line To Ice Maker Clean | Gabesrepair | Refrigerator & Freezer Repair | 4 | 02-22-2009 12:59 PM |
| Whirlpool fridge leaks bad when connecting water line | jherre6 | Refrigerator & Freezer Repair | 5 | 11-26-2008 08:45 AM |
