Discuss
Amana Frig not cooling, but freezer works
 in
Refrigerator & Freezer Repair
Good morning, I think this refrigerator (Amana ARB2117AW, or PARB2117AW1) is probably over 10 years. We bought the home in
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Amana Frig not cooling, but freezer works
  #1 (permalink)
Old 10-13-2011, 10:24 AM
Junior Member
drewbenson is on a distinguished road
Red face Amana Frig not cooling, but freezer works
Model Number: ARB2117AW   Brand: Amana   Age: More than 10 years
Good morning,
I think this refrigerator (Amana ARB2117AW, or PARB2117AW1) is probably over 10 years. We bought the home in 2004 and it was in the home then, so it is at least 7 years old.
The frigerator does not seem to be cooling, but freezer is cold (and has lots of frost covering interior, if that matters).
The cool setting on the fridge is turned all the way to max.
Any help would be greatly appreciated.
Thank you!
Related Models
Amana ARB2117AW REF - BOTTOM MOUNTS
Amana ARB2117BB REF - BOTTOM MOUNTS
Amana ARB2117BC REF - BOTTOM MOUNTS
Amana ARB2117BS REF - BOTTOM MOUNTS
Amana ARB2117BW REF - BOTTOM MOUNTS
Amana ARB2205CB REF - BOTTOM MOUNTS
Amana ARB2205CC REF - BOTTOM MOUNTS
Amana ARB2205CS REF - BOTTOM MOUNTS
Amana ARB2205CW REF - BOTTOM MOUNTS
Amana ARB220RCB REF - BOTTOM MOUNTS
Amana ARB220RCC REF - BOTTOM MOUNTS
Amana ARB220RCW REF - BOTTOM MOUNTS
Amana ARB220ZCB REF - BOTTOM MOUNTS
Amana ARB220ZCC REF - BOTTOM MOUNTS
Amana ARB220ZCS REF - BOTTOM MOUNTS
Amana ARB220ZCW REF - BOTTOM MOUNTS
Amana ARB2214CB REF - BOTTOM MOUNTS
Amana ARB2214CC REF - BOTTOM MOUNTS
Amana ARB2214CSL REF - BOTTOM MOUNTS
Amana ARB2214CSR REF - BOTTOM MOUNTS
Amana ARB2214CW REF - BOTTOM MOUNTS
Amana ARB2217CB REF - BOTTOM MOUNTS
Amana ARB2217CC REF - BOTTOM MOUNTS
Amana ARB2217CSL REF - BOTTOM MOUNTS
Amana ARB2217CSR REF - BOTTOM MOUNTS
Amana ARB2217CW REF - BOTTOM MOUNTS
Amana ARB224RCB REF - BOTTOM MOUNTS
Amana ARB224RCC REF - BOTTOM MOUNTS
Amana ARB224RCW REF - BOTTOM MOUNTS
Amana ARB2257CB REF - BOTTOM MOUNTS
Amana ARB2257CC REF - BOTTOM MOUNTS
Amana ARB2257CSL REF - BOTTOM MOUNTS
Amana ARB2257CSR REF - BOTTOM MOUNTS
Amana ARB2257CW REF - BOTTOM MOUNTS
Amana ARB2259CB REF - BOTTOM MOUNTS
Amana ARB2259CC REF - BOTTOM MOUNTS
Amana ARB2259CS REF - BOTTOM MOUNTS
Amana ARB2259CW REF - BOTTOM MOUNTS
Amana ARB2517CB REF - BOTTOM MOUNTS
Amana ARB2517CC REF - BOTTOM MOUNTS
Amana ARB2517CSL REF - BOTTOM MOUNTS
Amana ARB2517CSR REF - BOTTOM MOUNTS
Amana ARB2517CW REF - BOTTOM MOUNTS
Amana ARB2557CB REF - BOTTOM MOUNTS
Amana ARB2557CC REF - BOTTOM MOUNTS
Amana ARB2557CSL REF - BOTTOM MOUNTS
Amana ARB2557CSR REF - BOTTOM MOUNTS
Amana ARB2557CW REF - BOTTOM MOUNTS
Amana ARB8057CB REF - BOTTOM MOUNTS
Amana ARB8057CC REF - BOTTOM MOUNTS
Amana ARB8057CSL REF - BOTTOM MOUNTS
Amana ARB8057CSR REF - BOTTOM MOUNTS
Amana ARB8057CW REF - BOTTOM MOUNTS
Amana ARB9058CB REF - BOTTOM MOUNTS
Amana ARB9058CS REF - BOTTOM MOUNTS
Amana ARB9058CW REF - BOTTOM MOUNTS
Amana ARB9059CS REF - BOTTOM MOUNTS
Amana ARC-1 RANGE- S/C S/I DDRAFT GAS
Amana ARC-100 RANGE- S/C S/I DDRAFT GAS
Amana ARC-100B RANGE- S/C S/I DDRAFT GAS
Amana ARC-1B RANGE- S/C S/I DDRAFT GAS
Amana ARC-2 RANGE- S/C S/I DDRAFT GAS
Amana ARC-2B RANGE- S/C S/I DDRAFT GAS
Amana ARC-506 RANGE- S/C S/I DDRAFT ELE
Amana ARC100B RANGE- S/C S/I DDRAFT ELE
Amana ARC100D RANGE- S/C S/I DDRAFT ELE
Amana ARC1B RANGE- S/C S/I DDRAFT ELE
Amana ARC502W RANGE- S/C S/I DDRAFT ELE
Amana ARC505 RANGE- S/C F/S ELE
Amana ARC505B RANGE- S/C S/I DDRAFT ELE
Amana ARC515 RANGE- S/C S/I DDRAFT ELE
Amana ARC515 RANGE- S/C S/I DDRAFT GAS
Amana ARC700E Range - S/c S/i Ddraft Ele
Amana ARC700E RANGE- S/C S/I DDRAFT ELE
Amana ARC700LL RANGE- S/C S/I DDRAFT ELE
Amana ARC700WW RANGE- S/C S/I DDRAFT ELE
Amana ARDS800E RANGE- S/C S/I DDRAFT ELE
Amana ARDS800WW RANGE- S/C S/I DDRAFT ELE
Amana ARDS801E RANGE- S/C S/I DDRAFT ELE
Amana ARDS801WW RANGE- S/C S/I DDRAFT ELE
Amana ARDS802E RANGE- S/C S/I DDRAFT ELE
  #2 (permalink)
Old 10-13-2011, 03:51 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Looks like your refrigerator is not defrosting properly. You can find the troubleshooting instructions in one of our previous threads: Freezer is fine, refrigerator is too warm.
Here are the breakdown diagrams and Replacement parts for AMANA ARB2117AW REF - BOTTOM MOUNTS | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 10-13-2011, 03:58 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Originally Posted by drewbenson View Post
Good morning,
Thank you!
Drew,
Sounds like two possibilities :
The freezer drawer is not closing and sealing properly.
Use a piece of paper, insert the paper between the door seal and the cabinet flange, close the door on the paper, and pull out on the paper, there should be a slight resistance when you pull, all the way around the drawer.
You have a defrost issue,
You will need to remove everything in the freezer, and the drawer, remove the back panel of the freezer compartment and check the defrost thermostat and defrost heater for closed circuits with a multimeter, and de ice the evaporator coils with a hair dryer or hot water. If the heatr and thermostat check properly, you'd need to replace the defost timer.
Thanks and Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer works Frig not cooling kietbusby Refrigerator & Freezer Repair 0 08-25-2010 09:47 PM
amana frig does not cool on top freezer works rrivera7 Refrigerator & Freezer Repair 0 06-30-2010 03:28 PM
GE Freezer works, frig warm Jmccarr55 Refrigerator & Freezer Repair 0 05-06-2010 04:46 PM
freezer works Frig is warm crbirdx Refrigerator & Freezer Repair 2 07-03-2009 09:27 AM
Freezer works but Frig is warm ct2023 Refrigerator & Freezer Repair 0 04-09-2008 10:26 AM
