| » leaking water tank |
Model Number: psd2350dr Brand: Maytag Age: 1 - 5 years
i have a maytag refrig model psd2350dr (performa) side by side with water/ice in the door. Everything works fine except there is a pinhole leak in the water tank which is located in the lower refrig compartment. It looks like it is made from polyethylene(milk jug material), but when I try to pacth it or apply a pin point of heat to "remelt" it it just doesn't work.The pinhole is on the 'inside' of the bend, and right on a seam. Of course no other sealant will work either.
2 questions; Any one have any ideas on patching the pinhole? If I have to replace the tank does the new tank come with the water lines already attached? ( the fittings look like they are heated, not just a hose clamp on a nipple) If the new tank comes with the lines already attached, what is the fitting on the other end(a heat fitting like on the tank end, or clamp and nipple, or pressure fitting?) The water line is standard 1/4 " line. Thanks for the help doug Ads By Google Related Models |
Here is your tank. It does have the hoses attached.http://www.appliancepartspros.com/PartImage.aspx?imgid=Z3BqLjBfbXNfOTg2MzAwMTYvTFBXL 3NvdG9ocHRyYXAv
I would try an epoxy made for plastic. An auto parts store has different kinds for different materials. |
| Display Modes | |
| GE Water Tank installation | kenaldridge | Refrigerator & Freezer Repair | 1 | 07-31-2009 05:00 PM |
| replaced water tank now nothing | garyfull | Refrigerator & Freezer Repair | 1 | 07-26-2009 09:39 AM |
| tank water assy | lrdelacruz | Refrigerator & Freezer Repair | 0 | 07-20-2009 01:21 PM |
| Water Tank Repair | clyneal | Refrigerator & Freezer Repair | 0 | 07-03-2009 07:30 PM |
| Water Softner not removing water from tank | kysnake00 | General Talk | 0 | 12-01-2007 01:02 PM |
