My ice maker does not send water the the tray. I have replaced the unit and also checked to see if water was comming from the line, which it is.
Do you have any ideas of what could be wrong?
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Thanks for the feedback. Do you have a way we can reach you for help when we go to switch the wires.
Originally Posted by: cjauletta My ice maker does not send water the the tray. I have replaced the unit and also checked to see if water was comming from the line, which it is.
Do you have any ideas of what could be wrong? HI check the water inlet valve it is controled by the ice maker
CJ,
Have you received any resolution to this issue? I know it's 2 years past but I'm having the same issue with the same ice maker model.
Chris
