Discuss
Freezer Won't Freeze, Both Sides Stuck at @ 40º
 in
Refrigerator & Freezer Repair
I have been reading some of the other posts and am at a standstill right now. I have seen this
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer Won't Freeze, Both Sides Stuck at @ 40º
  #1 (permalink)
Old 10-07-2011, 04:53 PM
Junior Member
obx166ec is on a distinguished road
Default Freezer Won't Freeze, Both Sides Stuck at @ 40º
Model Number: FRS26R4CB6   Brand: Frigidaire   Age: 5 - 10 years
I have been reading some of the other posts and am at a standstill right now. I have seen this problem where the Frigidaire was working fine and all of a sudden the freezer stopped freezing and leveled out at about 40º. I first vacuumed out some dust off the coils in the back. The compressor is warm to the touch and the condenser fan is working. I took the lower back panel off inside and there was a frost buildup just on the top layer of the evaporator coils and that fan is running also. At first I thought it was the defrost timer and checked the defrost thermostat. I sprayed it for a few minutes with some diagnostic freeze spray and the defrost coil never came on. It ohm'd out good and the end looked a little corroded and cleaned it. After putting it back on, the top layer of the evaporator gets frosted to include the thermostat and apparently at some point, the defrost coil must come on, as it defrosts and the temperature gets up to about 55-60º. The compressor seems to kick on and it frosts up again and goes through the same cycle. It only seems to frost the first row of the evaporator coils. Any suggestions for this type of cycle. Refrigerator side seems to stay at around 40-50º. Temp controls are both at factory setting and turning up colder has no adverse effect. Any suggestions?
Ads By Google
Related Models
Frigidaire FRS26R4CB6 Frigidaire/refrigerator
Frigidaire FRS26R4CB7 Frigidaire/refrigerator
Frigidaire FRS26R4CB8 Frigidaire/refrigerator
Frigidaire FRS26R4CBA Frigidaire/refrigerator
Frigidaire FRS26R4CBB Frigidaire/refrigerator
Frigidaire FRS26R4CBC Frigidaire/refrigerator
Frigidaire FRS26R4CBD Frigidaire/refrigerator
Frigidaire FRS26R4CBE Frigidaire/refrigerator
Frigidaire FRS26R4CBR Frigidaire/refrigerator
Frigidaire FRS26R4CBS Frigidaire/refrigerator
Frigidaire FRS26R4CQ0 Frigidaire/refrigerator
Frigidaire FRS26R4CQ1 Frigidaire/refrigerator
Frigidaire FRS26R4CQ2 Frigidaire/refrigerator
Frigidaire FRS26R4CQ3 Frigidaire/refrigerator
Frigidaire FRS26R4CQ4 Frigidaire/refrigerator
Frigidaire FRS26R4CQ5 Frigidaire/refrigerator
Frigidaire FRS26R4CQ6 Frigidaire/refrigerator
Frigidaire FRS26R4CQ7 Frigidaire/refrigerator
Frigidaire FRS26R4CQ8 Frigidaire/refrigerator
Frigidaire FRS26R4CQB Frigidaire/refrigerator
Frigidaire FRS26R4CQC Frigidaire/refrigerator
Frigidaire FRS26R4CQD Frigidaire/refrigerator
Frigidaire FRS26R4CQE Frigidaire/refrigerator
Frigidaire FRS26R4CQS Frigidaire/refrigerator
Frigidaire FRS26R4CW0 Frigidaire/refrigerator
Frigidaire FRS26R4CW1 Frigidaire/refrigerator
Frigidaire FRS26R4CW2 Frigidaire/refrigerator
Frigidaire FRS26R4CW3 Frigidaire/refrigerator
Frigidaire FRS26R4CW4 Frigidaire/refrigerator
Frigidaire FRS26R4CW5 Frigidaire/refrigerator
Frigidaire FRS26R4CW6 Frigidaire/refrigerator
Frigidaire FRS26R4CW7 Frigidaire/refrigerator
Frigidaire FRS26R4CW8 Frigidaire/refrigerator
Frigidaire FRS26R4CW9 Frigidaire/refrigerator
Frigidaire FRS26R4CWA Frigidaire/refrigerator
Frigidaire FRS26R4CWB Frigidaire/refrigerator
Frigidaire FRS26R4CWC Frigidaire/refrigerator
Frigidaire FRS26R4CWD Frigidaire/refrigerator
Frigidaire FRS26R4CWE Frigidaire/refrigerator
Frigidaire FRS26R4CWR Frigidaire/refrigerator
Frigidaire FRS26R4CWS Frigidaire/refrigerator
Frigidaire FRS26RBBW0 Frigidaire/refrigerator
Frigidaire FRS26RBBW1 Frigidaire/refrigerator
Frigidaire FRS26RBCW0 Frigidaire/refrigerator
Frigidaire FRS26RBCW1 Frigidaire/refrigerator
Frigidaire FRS26RBCW2 Frigidaire/refrigerator
Frigidaire FRS26RBCW3 Frigidaire/refrigerator
Frigidaire FRS26RBCW4 Frigidaire/refrigerator
Frigidaire FRS26RBCW5 Frigidaire/refrigerator
Frigidaire FRS26RBCW6 Frigidaire/refrigerator
Frigidaire FRS26RBCW8 Frigidaire/refrigerator
Frigidaire FRS26RBCW9 Frigidaire/refrigerator
Frigidaire FRS26RBCWA Frigidaire/refrigerator
Frigidaire FRS26RLECS0 Frigidaire/refrigerator
Frigidaire FRS26RLECS1 Frigidaire/refrigerator
Frigidaire FRS26RLECS2 Frigidaire/refrigerator
Frigidaire FRS26RLECS3 Frigidaire/refrigerator
Frigidaire FRS26RLECS4 Frigidaire/refrigerator
Frigidaire FRS26RLECS6 Frigidaire/refrigerator
Frigidaire FRS26RLECS7 Frigidaire/refrigerator
Frigidaire FRS26RLECS8 Frigidaire/refrigerator
Frigidaire FRS26RLECS9 Frigidaire/refrigerator
Frigidaire FRS26RLECSA Frigidaire/refrigerator
Frigidaire FRS26RLECSB Frigidaire/refrigerator
Frigidaire FRS26RLECSC Frigidaire/refrigerator
Frigidaire FRS26RLECSE Frigidaire/refrigerator
Frigidaire FRS26RLECSF Frigidaire/refrigerator
Frigidaire FRS26RLECSG Frigidaire/refrigerator
Frigidaire FRS26RLECSH Frigidaire/refrigerator
Frigidaire FRS26RLECSN Frigidaire/refrigerator
Frigidaire FRS26RLECSP Frigidaire/refrigertor
Frigidaire FRS26RLECSR Frigidaire/refrigerator
Frigidaire FRS26RLECSS Frigidaire/refrigerator
Frigidaire FRS26RLECST Frigidaire/refrigerator
Frigidaire FRS26SM4AW0 Frigidaire/refrigerator
Frigidaire FRS26SM4AW2 Frigidaire/refrigerator
Frigidaire FRS26SM4AW3 Frigidaire/refrigerator
Frigidaire FRS26TS6DW1 Frigidaire/refrigerator
Frigidaire FRS26TS6DW2 Frigidaire/refrigerator
Frigidaire FRS26TS6DW3 Frigidaire/refrigerator
Frigidaire FRS26TS6DW5 Frigidaire/refrigerator
Frigidaire FRS26TS7DB0 Frigidaire/refrigerator
Frigidaire FRS26TS7DB1 Frigidaire/refrigerator
Frigidaire FRS26TS7DB2 Frigidaire/refrigerator
Frigidaire FRS26TS7DB3 Frigidaire/refrigerator
Frigidaire FRS26TS7DB5 Frigidaire/refrigerator
Frigidaire FRS26TS7DW0 Frigidaire/refrigerator
Frigidaire FRS26TS7DW1 Frigidaire/refrigerator
Frigidaire FRS26TS7DW2 Frigidaire/refrigerator
Frigidaire FRS26TS7DW3 Frigidaire/refrigerator
Frigidaire FRS26TS7DW5 Frigidaire/refrigerator
Frigidaire FRS26W2AQ1 Frigidaire/refrigerator
Frigidaire FRS26W2AQ2 Frigidaire/refrigerator
Frigidaire FRS26W2AQ3 Frigidaire/refrigerator
Frigidaire FRS26W2AQ4 Frigidaire/refrigerator
Frigidaire FRS26W2AQ5 Frigidaire/refrigerator
Frigidaire FRS26W2AQ6 Frigidaire/refrigerator
Frigidaire FRS26W2AQ7 Frigidaire/refrigerator
Frigidaire FRS26W2AQ8 Frigidaire/refrigerator
Frigidaire FRS26W2AQ9 Frigidaire/refrigerator
Frigidaire FRS26W2AQA Frigidaire/refrigerator
Frigidaire FRS26W2AQB Frigidaire/refrigerator
Frigidaire FRS26W2AQC Frigidaire/refrigerator
Frigidaire FRS26W2AQD Frigidaire/refrigerator
Frigidaire FRS26W2AQE Frigidaire/refrigerator
Frigidaire FRS26W2AW1 Frigidaire/refrigerator
Frigidaire FRS26W2AW2 Frigidaire/refrigerator
Frigidaire FRS26W2AW3 Frigidaire/refrigerator
Frigidaire FRS26W2AW4 Frigidaire/refrigerator
Frigidaire FRS26W2AW5 Frigidaire/refrigerator
Frigidaire FRS26W2AW6 Frigidaire/refrigerator
Frigidaire FRS26W2AW7 Frigidaire/refrigerator
Frigidaire FRS26W2AW8 Frigidaire/refrigerator
Frigidaire FRS26W2AW9 Frigidaire/refrigerator
Frigidaire FRS26W2AWA Frigidaire/refrigerator
Frigidaire FRS26W2AWB Frigidaire/refrigerator
Frigidaire FRS26W2AWC Frigidaire/refrigerator
Frigidaire FRS26W2AWD Frigidaire/refrigerator
Frigidaire FRS26W2AWE Frigidaire/refrigerator
Frigidaire FRS26W2AWF Frigidaire/refrigerator
  #2 (permalink)
Old 10-08-2011, 06:18 PM
Junior Member
Default
OK, here is additional info on my problem. Just about 10 minutes ago, I physically saw the defrost heater coil come on. It stayed glowing orange for about 7-8 minutes, long enough for the frost on the top row of the evaporator to melt. The remaining 7 or 8 rows of coils on the evaporator had no frost on them or in between the fins like the top row. A clicking noise was heard, which I would assume it was the defrost thermostat getting warm and disengaged the defrost heater coil. Is it possible that one of the temperature controls can be bad? for the past several days they have been set to the factory setting position because turning them up to colder had no adverse effect. Any help?
  #3 (permalink)
Old 10-11-2011, 02:47 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
You have refrigeration problems for a pro to look at, only pressure gauges and amprobe will show what the problem is.
__________________
  #4 (permalink)
Old 10-11-2011, 05:10 AM
Junior Member
Default Richappy
That's for your input. I was thinking it was looking more like a system problem than an easily replaceable component.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
freezer freeze food for a day and food become soft and freeze again 12305 Refrigerator & Freezer Repair 1 02-16-2011 02:52 AM
Hot exterior sides freezer works msavoy1999 Refrigerator & Freezer Repair 0 05-25-2010 05:56 AM
Freezer thawing at bottom, sides of freezer hot Tracey Ludwig Refrigerator & Freezer Repair 1 10-06-2009 02:38 PM
Kenmore Freezer warm sides / not freezing jbade Refrigerator & Freezer Repair 1 06-09-2009 08:52 PM
Freezer: replaced relay (no freeze, clicks)now compressor overheats, stopping freeze mikel33 Refrigerator & Freezer Repair 2 04-22-2009 11:12 AM
