| » Amana bottom freezer ice build-up and leaking |
Model Number: ABB1924WEQO Brand: Amana Age: 1 - 5 years
I own an Amana bottom freezer refrigerator that is just over a year old. Ice has been accumulating in the bottom of the freezer compartment and there is occassionally a puddle of water on the floor. I opened the freezer door and let the ice thaw and melt and that seemed to work for a while. But, now the problem is back and I'm thinking it may be a problem with the drain. The model number is ABB1924WEQ
Hello. Yes, it sounds like the drain is clogged and will need to be cleaned out. Remove the door and the basket from the freezer. Press the tabs and remove the glides out of the freezer. Remove either the left or right glide rail to remove the back panel. Remove the center air grill by pressing the tab in the center with a straight screwdriver and pry toward the center in the two slots on the sides of the grill. remove the thermistor cover on the right side by prying the slot with the screwdriver. Now remove the screws holding the panel in place, and remove the icemaker, if your unit has one. Remove the back panel from the unit.
Now you can access the drain under the evaporator coils. Use hot water and a turkey baster. Push the hot water into the drain hole, and clear out any ice and debris in the drain. When the drain flows freely with the hot water, reinstall the components for the freezer in reverse order. Hope this helps.
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Jeff K. / APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| amana bottom freezer leaking | joe1934 | Refrigerator & Freezer Repair | 7 | 03-08-2010 12:44 PM |
| Ice build up on bottom of freezer side | leonet99 | Refrigerator & Freezer Repair | 3 | 07-21-2009 03:30 PM |
| Ice build up on bottom of freezer side | leonet99 | Refrigerator & Freezer Repair | 1 | 11-19-2008 12:16 PM |
| Whirlpool Freezer with ice build up @ bottom | indelible5 | Refrigerator & Freezer Repair | 6 | 10-20-2008 10:34 AM |
| ice build up in the bottom of the freezer | lauder | Refrigerator & Freezer Repair | 1 | 08-22-2007 07:53 PM |
