Discuss
Fridge and Freezer Not Cooling
 in
Refrigerator & Freezer Repair
My 3 year old Kenmore fridge/freezer is not cold. The fan in the freezer runs and the light comes on
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Fridge and Freezer Not Cooling
  #1 (permalink)
Old 10-06-2011, 12:42 PM
Junior Member
DABrilliant is on a distinguished road
Default Fridge and Freezer Not Cooling
Model Number: 253.7480240G   Brand: Kenmore   Age: 1 - 5 years
My 3 year old Kenmore fridge/freezer is not cold. The fan in the freezer runs and the light comes on when you open the door. I adjusted the temperature to 0 and heard the fan shut off. When I turned the temperature back to the cold setting, the fan started again and the compressor started up with a quiet hum. The compressor continued making that noise. It vibrates gentlyand it quite hot to the touch. I'm not sure what I'm looking for. Is the compressor bad even though I don't hear a hum...click noise? Could it be a part of the defrost system that's gone out? I just don't know where to start. Any help would be greatly appreciated.
Also, I did unplug the unit to let it defrost completely. That did not fix the problem.
Related Models
Frigidaire 2530A GAS RANGE
Frigidaire 2530B GAS RANGE
Frigidaire 2530C GAS RANGE
Frigidaire 2530D GAS RANGE
Frigidaire 2530E GAS RANGE
Kenmore 25310301000 CHEST FREEZER
Kenmore 25310301001 CHEST FREEZER
Kenmore 25310311000 CHEST FREEZER
Kenmore 25310311001 CHEST FREEZER
Kenmore 25310311002 FREEZER
Kenmore 25310911990 FREEZER
Kenmore 25310911991 CHEST FREEZER
Kenmore 25310911992 CHEST FREEZER
Kenmore 25311301100 FREEZER
Kenmore 25311301101 FREEZER
Kenmore 25311311100 CHEST FREEZER
Kenmore 25311312100 FREEZER
Kenmore 25311312101 FREEZER
Kenmore 25311312102 SEARS/FREEZER
Kenmore 25311321100 CHEST FREEZER
Kenmore 25311321101 FREEZER
Kenmore 25311351100 FREEZER
Kenmore 25311351101 CHEST FREEZER
Kenmore 25311351102 FREEZER
Kenmore 25311511100 CHEST FREEZER
Kenmore 25311511101 FREEZER
Kenmore 25311521100 FREEZER
Kenmore 25311521102 CHEST FREEZER
Kenmore 25311521103 FREEZER
Kenmore 25311531100 FREEZER
Kenmore 25311531101 FREEZER
Kenmore 25311531102 FREEZER
Kenmore 25311531103 FREEZER
Kenmore 25311541100 CHEST FREEZER
Kenmore 25311541102 FREEZER
Kenmore 25311711100 FREEZER
Kenmore 25311711101 CHEST FREEZER
Kenmore 25311711102 FREEZER
Kenmore 25311821100 FREEZER
Kenmore 25311821101 FREEZER
Kenmore 25311911100 FREEZER
Kenmore 25311911101 FREEZER
Kenmore 25312021100 FREEZER
Kenmore 25312021101 FREEZER
Kenmore 25312021102 FREEZER
Kenmore 25312541100 FREEZER
Kenmore 25312541102 SEARS/FREEZER
Kenmore 25312551100 FREEZER
Kenmore 25313009100 FREEZER
Kenmore 25313051100 FREEZER
Kenmore 25313051101 FREEZER
Kenmore 25313051102 FREEZER
Kenmore 25313051103 FREEZER
Kenmore 25313312101 FREEZER
Kenmore 25313351100 FREEZER
Kenmore 25313500100 FREEZER
Kenmore 25313500101 FREEZER
Kenmore 25313500102 FREEZER
Kenmore 25313500103 FREEZER
Kenmore 25313511100 CHEST FREEZER
Kenmore 25313511101 FREEZER
Kenmore 25313511102 FREEZER
Kenmore 25313541101 FREEZER
Kenmore 25313541102 FREEZER
Kenmore 25313551100 FREEZER
Kenmore 25313551101 FREEZER
Kenmore 25313711100 FREEZER
Kenmore 25313711101 FREEZER
Kenmore 25313711102 FREEZER
Kenmore 25313712100 FREEZER
Kenmore 25313712101 FREEZER
Kenmore 25313911100 FREEZER
Kenmore 25313911101 FREEZER
Kenmore 25313911102 FREEZER
Kenmore 25314092101 FREEZER
Kenmore 25314092102 FREEZER
Kenmore 25314092103 FREEZER
Kenmore 25314342100 FREEZER
Kenmore 25314342101 FREEZER
Kenmore 25314342102 FREEZER
Kenmore 25314352100 FREEZER
Kenmore 25314352101 FREEZER
Kenmore 25314352102 FREEZER
Kenmore 25314502100 FREEZER
Kenmore 25314502101 FREEZER
Kenmore 25314502102 FREEZER
Kenmore 25314502103 FREEZER
Kenmore 25314502104 FREEZER
Kenmore 25314502105 FREEZER
Kenmore 25314512100 FREEZER
Kenmore 25314512101 FREEZER
Kenmore 25314512102 FREEZER
Kenmore 25314512103 FREEZER
Kenmore 25314512104 FREEZER
Kenmore 25314542100 FREEZER
Kenmore 25314542101 FREEZER
Kenmore 25314542102 FREEZER
Kenmore 25314542103 FREEZER
Kenmore 25314542104 FREEZER
Kenmore 25314542105 FREEZER
Kenmore 25314552100 FREEZER
Kenmore 25314552101 FREEZER
Kenmore 25314552102 FREEZER
Kenmore 25314582100 FREEZER
Kenmore 25314592100 FREEZER
Kenmore 25314592101 FREEZER
Kenmore 25314592102 FREEZER
Kenmore 25314702100 FREEZER
Kenmore 25314702101 FREEZER
Kenmore 25314702102 FREEZER
Kenmore 25314702103 FREEZER
Kenmore 25314702104 FREEZER
Kenmore 25314712100 FREEZER
Kenmore 25314712101 FREEZER
Kenmore 25314712102 FREEZER
Kenmore 25314712103 FREEZER
Kenmore 25314772100 FREEZER
Kenmore 25314772101 FREEZER
Kenmore 25314772102 FREEZER
Kenmore 25314772103 FREEZER
  #2 (permalink)
Old 10-06-2011, 02:35 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
DA,
Actually, everything sounds good, based on your post. Your compressor should have a light humming noise, a slight vibration and get hot, if its running, it should not make a loud click noise, and be room temperature or below, that would indicate a compressor or sealed system issue.
You may want to check your evaporator coil for a proper frost pattern. Unplug the power cord, empty the freezer compartment, and remove the back wall of the freezer( 4 screws) and be careful of the sharp edges, and disconnecting the wiring harness connections. plug the power cord in, turn on the fridge and wait 5 to 10 minutes, There should be an even coating of frost on all the coils of the evaporator. Also check and make sure the interior lights go out when you close the door.
Drop us a line and let us know what you find, so we can help from there
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 10-12-2011, 08:13 AM
Junior Member
Default Still no luck
I took the back off the freezer and let it run just as you said. There's no frost on the coils. Also, the light does turn off when the door is closed. So, what should I look at next?
  #4 (permalink)
Old 10-12-2011, 12:03 PM
Senior Expert
Default
DA,
Ok, no frost on the coil, but everything else seems to be working.
Now, move the unit out and unplug the power cord( leave the control in the ON position) Remove the lower access panel on the back of the refrigerator and wait 5 to 10 minutes, you can clean up all the debris on the condenser coils, fan etc. Then plug the power cord in ( be careful, there maybe sparks at the outlet) and listen for the compressor to start and run, or a loud click noise. You can also touch the top of the compressor and feel the vibration, if the motor is running.
If we need to go further, we're going to need a multimeter to test voltage and circuits to the compressor and back to the control(s) .
Part number: AP3873826
__________________
Joe M. APP TEAM
  #5 (permalink)
Old 10-12-2011, 12:42 PM
Junior Member
Default i guess we need to check voltages
The condenser coils are located on the back so there is no condenser fan. They are clean. The compressor comes on with a soft hum and you can feel a slight vibration. There is no click sound. What should I be looking for with the multimeter?
  #6 (permalink)
Old 10-13-2011, 06:11 AM
Senior Expert
Default
DA,
We don't need a meter for now.
Based on the description, you'll need a servicer to check and repair the sealed system leak, or you may want to consider a new refrigerator.
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Fridge/Freezer Not Cooling Freezer Properly woody1397 Refrigerator & Freezer Repair 1 02-02-2011 06:56 PM
started up s/s fridge. freezer working fine, but fridge is not cooling dkusko Refrigerator & Freezer Repair 0 09-05-2010 09:40 AM
Replacing Fridge Fan, freezer works, fridge not cooling dlake1 Refrigerator & Freezer Repair 4 07-22-2010 06:01 AM
Fridge Not Cooling And Freezer Feels Like Fridge Should ETHANSMOMMA Refrigerator & Freezer Repair 1 06-09-2010 10:39 PM
fridge and freezer not cooling estock Refrigerator & Freezer Repair 7 03-30-2008 11:11 AM
