My ice maker on the Frigidaire Gallery makes the ice and but it just does not throw them into the ice holder box. Everything works but it just does not throw the ice anymore. I have to manually break them off and dump out myself. I am not too sure what part I need.
Thanks Gene appreciate your help.
Ice maker stopped letting ice fall into box , but now it is just clicking rather then turning the arms to drop it , it says dont rotate by hand sowhat do I do next. this is the 3rd. ice maker I have had in the unit , and why dont they work to good. needsome help before replacing again
The ice maker definitely has gone bad and has to be replaced. When did you replace it last time?
Originally Posted by: Gene The ice maker definitely has gone bad and has to be replaced. When did you replace it last time?
Gene. I replaced the icemaker over 16 mos. ago, but how long are they made to last , this is the 3rd. one in 8 years. thank you
