Hi, I live in the Isle of Man and experiencing difficulties in getting someone to look at my fridge/freezer. The problem started in May when it stopped dispesning water and ice. Then the temperature began to read 44 dgs, but it was still cold and the freezer still worked. Now the temperature has gone altogether and there is no cooling or freezing. I can't get the control to work to change the temperature. I have swicthed the appliance off and turned the water off.
Should i replace the appliance or is it worth repairing?
