Discuss
Amana Refrigerator drain freeze problem
 in
Refrigerator & Freezer Repair
The refrigerator / freezer works great, but a reoccurring problem for years is the defrost drain hole from the freezer to
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Amana Refrigerator drain freeze problem
  #1 (permalink)
Old 12-06-2007, 10:44 AM
Scottrse1 Scottrse1 is offline
Junior Member
Scottrse1 is on a distinguished road
Default Amana Refrigerator drain freeze problem
Model Number: TL20NL   Brand: Amana   Age: More than 10 years
The refrigerator / freezer works great, but a reoccurring problem for years is the defrost drain hole from the freezer to the refrigerator freezes up a few times a year (or more). This causes a water backup which eventually it "rains" in the refrigerator. I found part AP118347 on your site "Drain Tube Freeze Up Kit" which I assume was an add on from the mfgr to deal with this issue. How does it install, does it come with detail instructions for installation into a unit that doesn't already have the wiring in place, etc. I think the settings in the freezer & frig are correct as I don't have ice in the milk and the ice cream is hard. The seals around the doors all look good. I don't have moisture around the door openings, etc. Can you help?
Scott
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-06-2007, 05:36 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
This is a very common problem with Amana top & bottom refrigerators and this kit works good. Honestly I do not remember the installation process (last time I did it was a few years ago) and I'm not sure about the installation instructions. You can call the APP (877-477-7278) and they will find it for you.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 12-09-2007, 08:20 AM
Junior Member
Default
Quote:
Thanks Gene for the response. I've dealt with the problems for years and appreciate your professional input to help me resolve it.
  #4 (permalink)
Old 09-02-2008, 04:55 PM
pjy pjy is offline
Junior Member
pjy is on a distinguished road
Default
Great help and advice! I have the same problem but do not know how to remove the freezer 'floor' tray. I removed the freezer rear panel to expose the evaporator but could not access the drain. I can't find any detailed diagrams on this old model. Any suggestions?
  #5 (permalink)
Old 09-02-2008, 06:55 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
pjy,
What is the complete model number of the refrigerator?
__________________
  #6 (permalink)
Old 09-03-2008, 12:53 PM
pjy pjy is offline
Junior Member
Default
Wow, I did not expect such a rapid response!
Model is TL20NL, Manufacturing # is P1106213WL.
As I mentioned previously, I opened the rear of the freezer but could not access any drain.
Thanks again for such a quick reply!
  #7 (permalink)
Old 09-03-2008, 03:29 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Locate the drip tray (#26 on the break down diagram) under the evaporator coil. The drain hole is in the center of the tray.
Use a hair dryer to defrost it. You can install the drain tube freeze up kit (#20 on the break down diagram) to prevent future freezing.
Here are the break down diagrams for the Amana refrigerator Model TL20N
__________________
  #8 (permalink)
Old 09-05-2008, 06:34 PM
pjy pjy is offline
Junior Member
Default
Thanks so much! I will take a look at the diagrams to see how to take the unit apart (once I consume all the items currently in the freezer. Unfortunately I filled it up a few days before this problem happened!).
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana washer spins but does not drain water out fjhead2000 Washer Repair 2 11-24-2007 09:44 AM
water disp on fridg(amana) door problem lemajune Refrigerator & Freezer Repair 9 11-14-2007 05:52 AM
Problem with Amana oven it just does not turn on nadmit Oven Repair (including Ranges and Cooktops) 1 10-22-2007 08:51 PM
Amana bottom freezer refrigerator MAL Refrigerator & Freezer Repair 1 08-18-2007 06:47 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
