Ive never worked on this model before and came upon it disassembled. I was told that the water inlet valve had leaked, it appears the valve body itself couples to a box that houses a small circuit board. This board is corroded. the parts dept. is showing this as one part #ap4339920, just making sure that the board and valve are included in this assembly. Any insight would be appreciated
