| » Freezer and fridge warm. |
Model Number: MFI2568AES Brand: Maytag Age: 5 - 10 years
Freezer and fridge is warm, I had to remove all the food. Everything seems to be working. The fan at the bottom (shroud condensor) is working, the freezer setting is 1, and the fridge setting is 36.
I replace the compressor starting device and capacitor (AP4079373), that did not solve the problem, fridge and freezer still warm. Ads By Google Related Models |
If the compressor is not running then the problem very likely is a bad HV control board (#13 on the diagram).
- The control board Part number: AP4014490 Here are the breakdown diagrams and Replacement parts for MAYTAG MFI2568AES REF - BOTTOM MOUNTS | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
I replace the HV board (AP4014490), that did not solve the problem, fridge and freezer still warm. When I put the new board in I had to program it and put in the code, it took about 10 minutes before the fan at the bottom started to work. hope you can help me.
Audley |
Audley,
Possible it stock in the defrost cycle. Run it in Service mode as described in the attached file and post the results. Gene.
__________________
I rechecked, and the Program Code is correct. I went in the Force Defrost Mode and the Fd and Sh flashed indicating the unit is in defrost. In the Service Test Mode I did Defrost Heater and Defrost Circuit.
Nothing seem to work the Freezer and Fridge still warm. |
Check the compressor for continuity as described in one of our previous threads: GE refrigerator just clicks but does not cool
If the compressor tests OK, replace the LV board (#13 on the diagram) - The LV board Part number: AP4080672 Gene.
__________________
I checked the compressor for continuity it was OK. I called in a repairman, he said the compressor need freeon gas, that would cost $358.00. I decided not to repair it and bought a new refridge.
Thanks for everything you did. Audley |
| Display Modes | |
| Whirlpool Fridge cold freezer warm fridge HELP!!! | arnoldthepig | Refrigerator & Freezer Repair | 3 | 08-01-2011 07:47 AM |
| Frigidaire Fridge Freezer/fridge warm | travellerdreamer | Refrigerator & Freezer Repair | 6 | 05-10-2011 01:43 PM |
| Amana Fridge w/ Bottom Freezer - Fridge is warm! | glad2beadad | Refrigerator & Freezer Repair | 0 | 02-27-2011 11:32 PM |
| Fridge is blowing hot air in freezer and warm air in fridge | Kat Zurawski | Refrigerator & Freezer Repair | 1 | 08-18-2009 09:28 AM |
| Freezer warm - Fridge warm | Carolyn | Refrigerator & Freezer Repair | 1 | 10-29-2007 04:33 AM |
