I have frigidaire refer. side by side and the freezer fan kicks on and off about 20 times before it finally starts running a normal cycle.I tested voltage at the fan when the problem was happening and the voltage to the freezer fan is going off and on . I would replace the control panel but it not available for this unit I have to figure out what part to replace .any help apreciated thanks jon
THIS FORUM IS DEAD!!!!!!! |
I tested the voltage to the fan with the fan hooked up when it was going on and off my volt meter was going on and off at the same time and i heard something clicking at the thermo.I guess it could be fan pulling to much current kicking a overload circuit on the adc ? I will test one more time with the fan disconected and mabe order new fan and adc.Thanks Jon..
