Refrigerator suddenly lost power last night. Checked Circuit Breaker Panel and power at the outlet-all are OK. No lights on front panel and frig does not run. Ran the troubleshooting checklist in the owners manual and everything checks out.
Do you have more troubleshooting suggestions?
Question: Is there a service manual available for this model?
Originally Posted by: mslota ...Ran the troubleshooting checklist in the owners manual and everything checks out... Can you describe it more detailed please? Gene.
Sure Gene. The refrigerator no longer runs, no LED lights on the front panel, no door lights, ice maker stopped working, compressor doesn't run. It is like something shut the power off to the unit.
I have checked the wall socket power and all is well. Is there a fuse or power board that could have burned up?
Matt
Matt, I did not see a fuse in this model, so looks like the problem is a bad power control board. It's located behind the display on the front panel. - The power control board Part number: AP4858246
