| » water in bottom of frige |
Model Number: EL7ATRRKQ01 Brand: Whirlpool Age: 1 - 5 years
There is no drain tube to clean that you can see from the outside. Removing the back panel appears to be quite a task. Is this the only way to solve this problem of water pooling in bottom? Mine has no freezer, frige only. Thank you.
Here is a parts breakdown
Replacement parts for WHIRLPOOL EL7ATRRKQ01 | AppliancePartsPros.com Looks like your drain tube is at the bottom of the unit (Item 13 in the "Cabinet, literature" section. Check at the drip tray to be sure it is not clogged here with dust etc. You could blow it clear with compressed air (just keep the pressure down) or what often works is a turkey baster and some warm water. Once clear flush it with a 10% bleach solution. Stuff likes to grow here and you want to kill it and flush it out.
__________________
There is no part #13 for draining. Smooth bottom. This tube is inside the back of the unit and "appears" to have to be accessed by removing the back unless there is a trick I am not aware of. You can see a short part of this tube by lying down and looking up inside the back but it is not easily accesable. Thanks.
I'll try it this evening when I get home. I guess this problem wasn't thought about when redesigned. It's flat backed, no tube, and very hard to get to underneath. I'm not sure what it is your talking about but I'll examine it and see if I can figure it out. Thank you so very much for your help.
It is a possibility since you see a lot of condensation.
If it is running down and can get into the unit, it could accumulate surprisingly fast one drop at a time. Without actually being there I cannot give an real opinion. In any case I would fix this first as it needs to repaired whether it is the cause of not.
__________________
| Display Modes | |
| Water still in the bottom | Gil Dawson | Dishwasher Repair | 7 | 10-12-2010 02:43 PM |
| water from bottom of sub zero | Jim Momorella | Refrigerator & Freezer Repair | 0 | 08-09-2009 06:55 PM |
| Water under frige | swulderk | Refrigerator & Freezer Repair | 1 | 05-10-2009 12:45 PM |
| frige and freezer frozen on bottom, warm on top | rosen123 | Refrigerator & Freezer Repair | 1 | 09-09-2008 12:45 PM |
| whirpool frige water dripping from dispenser | chaspitifer | Refrigerator & Freezer Repair | 1 | 08-09-2007 04:53 AM |
