Discuss
Fridge and Freezer both Warm
 in
Refrigerator & Freezer Repair
Neither the fridge or the freezer are cooling properly. There is no ice up on the evaporator in the back
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Fridge and Freezer both Warm
  #1 (permalink)
Old 12-05-2007, 07:28 PM
xsivspeed454 xsivspeed454 is offline
Junior Member
xsivspeed454 is on a distinguished road
Question Fridge and Freezer both Warm
Model Number: ET8MTKXKT0 1   Brand: Whirlpool   Age: 5 - 10 years
Neither the fridge or the freezer are cooling properly. There is no ice up on the evaporator in the back of the freezer. The fan at the compressor is working and both fans inside the fridge/freezer are working properly. I don't believe the compressor is running. It doesn't vibrate or anything when I plug the unit in. I have a dog so I cleaned as much dog hair out of the condensor as I could with my vacuum. I have checked continuity with an ohm-meter across the black 2-pin capacitor on the side of the compressor and i get about 4.50 M-ohms resistance across the terminals of the 2-pin capacitor mounted on the side of the compressor. The resistance reading gradually drop the longer I hold the meter on it. At about 4.30 M ohms I lose all continuity and when I swap the leads on the capacitor it starts back at about 4.50 M-Ohms and drops back off to about 4.30 M-Ohms. Is this a normal reading? What do you guys think? Is there common problems with these compressors or other electrical components that I can't seem to find?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-05-2007, 07:51 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem is a bad compressor. Remove the start devise from the compressor and check all windings for continuity across each other.
If any of pairs is open the compressor gone.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
TechnicianBrian's Avatar
TechnicianBrian TechnicianBrian is offline
Senior Expert
APP Volunteer
TechnicianBrian is on a distinguished road
Default
There should be a red and white wire going to the compressor starter. Check for 120vac at those two wires. If you do not have voltage, check the defrost timer and thermostat for voltage (tech sheet). They will be located in the housing in front of the fresh food section light bulb. If you do have voltage at the compressor, you will need to check the starter (item 15 in the unit parts) and ohm out the compressor windings.
TechnicianBrian
  #4 (permalink)
Old 12-06-2007, 03:05 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Pry off the side of the compressor the start relay and ohm across the terminals, if open order a new one. Should be the original factory part and not a substitute.
__________________
  #5 (permalink)
Old 12-06-2007, 06:39 AM
abbie abbie is offline
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
i,ll put my 2 cents worth in ,check the overload on the compressor part #13 if this is open replace .i had a few open in recent years.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
freezer works, fridge is warm debssanity Refrigerator & Freezer Repair 8 01-02-2008 08:26 PM
freezer cool/fridge warm grose70 Refrigerator & Freezer Repair 2 11-05-2007 07:07 PM
Freezer warm - Fridge warm Carolyn Refrigerator & Freezer Repair 1 10-29-2007 05:33 AM
freezer freezes but fridge is warm billybob Refrigerator & Freezer Repair 1 09-13-2007 03:50 AM
fridge side warm but freezer is cold shthd2u Refrigerator & Freezer Repair 1 09-09-2007 12:15 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
