Icemaker stopped making ice. Green light is flashing. I turned it off for awhile. Still blinking. I checked water valve, it engages and sprays water to the icemaker. What can I do?
Found the problem: The motor was bound up. The ice flip out fingers were pinching the plastic ice seperator tabs. I pulled the plastic tabs out of the way and reinstalled it properly so the flip out mechanism could rotate without binding on it.
