I have a frigidaire upright freezer. I noticed the other day that it has started leaking a lot of water from underneath. I checked the inside temperature and it is holding steady at 0 degrees. I checked the drain hose and it is clear. There is no water on the inside bottom of freezer. What else could it be coming from ? It almost looks like it is coming from underneath the compressor. Help !
