I ordered an icemaker from you, received and installed it. It will not fill. The icemaker kit is Electrolux #5303918277. Apparently the water supply is ok. I can see water in the plastic line from the the water line to the back of the refrigerator. The clip that holds the water line where it goes in to the refrigerator has not been touched. Theadjusring screw was adjusted the 1/2 turn that the instructions recommended. Could you educate me on what to do? Thank You, Alene Prebys
