| » KitchenAid won't defrost |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: KSRA25CNSS00 Brand: Kitchen Aid Age: 1 - 5 years
My refrigerator won't go into defrost mode. I have replaced the bi-metal thermostat with no luck. The evaporator freezes up solid after about 2 months and won't allow the air to flow through it to cool the fridge side. The freezer is fine. I don't have any guide for entering diagnostics. The heater ohms out fine. How can I manually defrost this unit? and What should I try next? There doesn't seem to be a defrost timer. I don't want to throw a $150 main PWB in to find out it didn't fix it.
Thanks Last edited by mch28 : 12-04-2007 at 06:28 PM. |
I think you hold the on button and water reset button for adout 3 secouds or so. then you can advance it by pressing the water reset button. I think its when you get to four or five that it goes into the defroost mode. then just keep pressing the water reset button till it back to normal run.
That's what I think too. I just don't know if I missed anything else. I can't seem to find a timer, so I believe it must be on the board.
Quote:
I tried that and it never went into diag. I unplugged and tried also within 13 seconds as suggested on another post. |
There is no timer and there is a diagnostics sheet behind the kick panel on the front of the fridge stuck up on the top. Slide your hand along and if no one has remover it you could find it. But I truely believe you will need a board as I ran into one of these fridges 2 weeks ago.
Quote:
No. The only control boards are in the refrigerator side at the top.
| Display Modes | |
| Defrost cycle | dl montana | Refrigerator & Freezer Repair | 1 | 03-30-2008 12:56 PM |
| Defrost timer | Greta Elliott | Refrigerator & Freezer Repair | 2 | 11-04-2007 12:58 AM |
| Defrost Not Working | danhutanu | Refrigerator & Freezer Repair | 1 | 10-24-2007 02:46 AM |
| defrost heater | Ashman | Refrigerator & Freezer Repair | 0 | 07-31-2007 01:13 PM |
| GE Top frz defrost problem? | vrocrider | Refrigerator & Freezer Repair | 1 | 07-21-2007 10:40 AM |
