| » KitchenAid won't defrost |
Quote:
In the mean time, anyone familiar with the diagnostics. The water filter and power button for 3 sec's aren't doing it. |
Quote:
Did you ever figure out what was wrong with your KitchenAid? I've got the same model (2-1/2 years old) and same problem. I also have the diagnostics sheet you were looking for. I ran the diagnostics and everything checked out. This has me somewhat puzzled but I'm still hoping it's the bi-metal (cheap) and not the control assly. (expensive). I'm thinking that my bi-metal might be stuck closed. After reading the diagnostics sheet, it sounds like this could throw off the electronic defrost cycle. The problem first occurred about a month ago when I noticed the refrig. side getting too warm. The freezer was OK but there was frost on the back wall. We have alot of power outages where I live so I figured the electronics might just need to be reset. After turning it off and unplugging the power cord, I powered it back up and the defrost cycle worked fine (until now). Anyway, if you succeeded in getting yours fixed and can share that info, I'd greatly appreciate it. |
Before replacing the control board, go to www.applianceaid.com There will be two different manual defrost procedures there, try both. Post results.
__________________
Quote:
Quote:
1.) Is it possible for the bi-metal to have stuck open, then snapped back closed after the hair dryer session? 2.) How often does the defrost cycle operate? |
| Display Modes | |
| Defrost cycle | dl montana | Refrigerator & Freezer Repair | 1 | 03-30-2008 01:56 PM |
| Defrost timer | Greta Elliott | Refrigerator & Freezer Repair | 2 | 11-04-2007 01:58 AM |
| Defrost Not Working | danhutanu | Refrigerator & Freezer Repair | 1 | 10-24-2007 03:46 AM |
| defrost heater | Ashman | Refrigerator & Freezer Repair | 0 | 07-31-2007 02:13 PM |
| GE Top frz defrost problem? | vrocrider | Refrigerator & Freezer Repair | 1 | 07-21-2007 11:40 AM |
