Discuss
Replacing the plumbing attached to a water valve
 in
Refrigerator & Freezer Repair
Hello, I've diagnosed a problem I'm having with a leaky ice maker and it's with this part, http://www.appliancepartspros.com/pa...009555&image=1 My only
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Replacing the plumbing attached to a water valve
  #1 (permalink)
Old 04-23-2009, 05:55 AM
Junior Member
raterus is on a distinguished road
Default Replacing the plumbing attached to a water valve
Brand: -brand-   Age: Less than 1 year
Hello,
My only issue now is how to replace the plumbing attached to it. On the defective part, the tubes just go into this piece, with no clear way to get them out, nothing to screw.
Can someone tell me the proper way to disconnect the old hoses, and put them into this new part? Will I need any additional hardware before I order?
Thanks,
--Michael
Ads By Google
  #2 (permalink)
Old 04-23-2009, 06:24 AM
Hardcore DIY'er
APP Volunteer
woodchuckie is on a distinguished road
Default
You slide the blue ring in while you pull the tube out and put it in the new one the same way.
  #3 (permalink)
Old 04-23-2009, 06:38 AM
Junior Member
Default
Hmm... So I actually push the blue ring in, with say a screw driver? I'm assuming that will open something up. Sorry for being so detailed, I just want to make sure I do this right and don't damage anything!
  #4 (permalink)
Old 04-23-2009, 12:24 PM
Hardcore DIY'er
APP Volunteer
Default
You should be able to move the ring with your fingers holding the tube in your hand.
  #5 (permalink)
Old 04-23-2009, 12:43 PM
Junior Member
Default
Thanks for your help, I appreciate it!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing Water Valve AP3192626 jonesware Refrigerator & Freezer Repair 9 09-11-2011 07:24 AM
Replacing secondary water valve kit jameskearns Refrigerator & Freezer Repair 2 11-03-2010 11:38 AM
Frigidaire Icemaker replacing water valve Bilsko Refrigerator & Freezer Repair 0 06-24-2009 03:29 PM
Replacing a water inlet valve Blondielehman Washer Repair 1 06-16-2009 04:52 PM
Replacing water valve jmvoakes Refrigerator & Freezer Repair 1 05-01-2009 01:09 PM
