Discuss
warm fridge
 in
Refrigerator & Freezer Repair
I recently purchased an evaporator fan and motor from Appliancepartspros.com for a Kitchen Aid built in fridge with a
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » warm fridge
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-04-2007, 10:16 AM
carson carson is offline
Junior Member
carson is on a distinguished road
Default warm fridge
Model Number: KBRC36FKS00   Brand: Kitchen Aid   Age: 5 - 10 years
I recently purchased an evaporator fan and motor from Appliancepartspros.com for a Kitchen Aid built in fridge with a bottom freezer. The motor was easy to place but the motor still would not kick on. I ran a diagnostic which indicated that the motor wasn't responding (which I already knew). Any suggestions. The unit is a little over 5 years an is a KBRC36FKS00.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-04-2007, 02:59 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
What was shown on the water filter status indicator when you ran a self diagnostic test?
Did you run it according to the service and wiring sheet?
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 12-04-2007, 04:34 PM
Junior Member
Default
I think so. I pushed the water filter reset and power buttons as indicated on the the directions for the fridge. Then advanced the test using the WFR button only. This is what I got: 1-1, 2-1, 3-2, 4-1, 5-2, 6-1 and 7-1. The 3-2 indicates that the evaporator fan isn't on I think. But I just replaced it. Could it be the mother board? The fridge beeps every couple of minutes and I want it fixed asap. What do you think?
  #4 (permalink)
Old 12-04-2007, 09:01 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The 5-2 reading means the compressor was off. You should run the compressor test again after at least 7 minutes interval.
Did you do it?
If you did, what was the result?
Perform all tests, described in the service manual to find out what exactly is wrong.
If there is something wrong with the compressor, it has very good manufacturer warranty.
__________________
  #5 (permalink)
Old 12-05-2007, 03:05 AM
Junior Member
Default
Did you do it?
Gene:
I ran the test again and the compressor turned on. The indicator went to 5-1 so it's OK. I am downloading the manual now and will follow your instructions. I will say though, that the freezer (bottom) is working fine. So the compressor is working. The fridge is cool, (41 degrees) but not the usual 35 degrees. So I think the problem may be in the evaporator fan relay (electronics) since the fan circulates freezer air to the fridge (top). The manual states that the service alarm beeps if the evaporator fan relay isn't functioning and it isn't. So there must be a problem with the relay. How is this fixed?
  #6 (permalink)
Old 12-05-2007, 12:31 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Test for DC voltage to the evaporator fan motor as described on the page 62 and, if it's wrong, go to the main board (#11 on the upper unit parts break down diagram) test on the page 65.
Possible the problem is there.
- The part number for the main control board AP3767641
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
freezer works, fridge is warm debssanity Refrigerator & Freezer Repair 8 01-02-2008 07:26 PM
freezer cool/fridge warm grose70 Refrigerator & Freezer Repair 2 11-05-2007 06:07 PM
Freezer warm - Fridge warm Carolyn Refrigerator & Freezer Repair 1 10-29-2007 04:33 AM
freezer freezes but fridge is warm billybob Refrigerator & Freezer Repair 1 09-13-2007 02:50 AM
fridge side warm but freezer is cold shthd2u Refrigerator & Freezer Repair 1 09-08-2007 11:15 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
